50 Trim
Old Jul 28, 2007 | 02:04 AM
dodgesrt4man's Avatar
dodgesrt4man
Default RE: 50 Trim
well i really didnt notice a difference and i would rather have bought a wideband fot that kind of money.just my thoughts on it,if its so good,can u tell me how it is so i dont think this no more cuz as of right now i think it was a waste?
Old Jul 29, 2007 | 11:16 AM
PSI Chick's Avatar
PSI Chick
Default RE: 50 Trim
s1 allows you to tune without throwing overboost codes. when those codes are thrown the ecu pulls timing. you can also then run a catless dp and not throw a code as well. the basic tune in a s1 ecu is much more aggressive than that of s0 when it comes to timing, and as such it's more friendly and helps the car respond better to modifications.
just because you don't "see" a gain doesn't mean that there aren't things going on that you're not aware of.........
Old Jul 29, 2007 | 11:58 PM
dodgesrt4man
Default RE: 50 Trim
im still just learning all this so im really good at it and it sounds like u are.now when u say tuning,is that witha wideband or on a dyno
Old Jul 30, 2007 | 11:20 AM
Burnnout's Avatar
Burnnout
Default RE: 50 Trim
A wideband is a gauge that displays your A/F ratios.......you can tune with either, but to tune you need a tuning device such as a DTEC, SAFC ect ect.
Old Jul 30, 2007 | 01:09 PM
dodgesrt4man
Default RE: 50 Trim
i really dont know what this stuff is,i had a 81 camaro runnin 10s on spray so they dont use computers so im really not sure,please tell me what it is so i can look in to it and know what it is.thanks for the help,at least i didnt waste my money on the stage one then
Old Jul 30, 2007 | 05:39 PM
PSI Chick's Avatar
PSI Chick
Default RE: 50 Trim
*smacks head* stage 1 isn'ta waste, i thought that was already explained.
Old Jul 31, 2007 | 04:16 PM
Aceburner's Avatar
Aceburner
Default RE: 50 Trim
Haha... I have a stage 1 and stage 2 pcm. I'm currently tuning with the stage 2. Stage 1 is definitely worth it when it comes to tuning. What we mean by tuning is that u take a fuel computer/piggyback system(hence DTEC, SAFC) and tune the fuel percentage to get more power out of the car. Now with a DTEC or SAFC your going to need something to monitor the changes u make (hence a wideband, scan gauge) for things like timing advance, knock retard and so on so u wont blow ur motor.
So remember when tuning you definitely need a wideband and a scan gauge preferably. Tuning is easy as hell, just time consuming.
Old Jul 31, 2007 | 05:16 PM
PSI Chick's Avatar
PSI Chick
Default RE: 50 Trim
for the most part a wideband is enough. once you get into other modifications that have to do with knock retard, injector duty, etc. then the scan gauge is worth it.
