greddy catch can install
Old Aug 7, 2007 | 07:01 PM
tyler819's Avatar
tyler819
Default greddy catch can install
i just bought a greddy oil catch can and was wondering where to mount it it? it also came with two hoses, one is 9mm for the pcv part and it also came with a small hose and two little elbow things thatthe little hoseconnects to and im guessing they screw into the can, how do i hook that part up?
Old Aug 7, 2007 | 07:08 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: greddy catch can install
Mounting is a problem, due to clearance issues. As for the parts you mention, the two "elbow things" screw into the top and bottom sideof the can and the clear hose goes in the middle - - it's just a way to show you how full your catch can is.....
Dusty
Old Aug 7, 2007 | 07:13 PM
tyler819's Avatar
tyler819
where do ppl normally mount theres, i wanted to mount it above the tranny or somethin out of the way of everything, where is a good spot for it? i bought the bracket that MP makes for it.
Old Aug 7, 2007 | 08:34 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
That's the reason mine is still in a drawer and I installed the $20.00 OCC......I didn't want to start drilling holes in a brand new car......
Dusty
Old Aug 8, 2007 | 12:11 AM
Dave_04's Avatar
Dave_04
If you have your stock air box you can put it on the passenger side fire wall just above the manifold directly behind the pcv valve. that is where mine is.
Bit of advice dont use the lines if it is the clear ones.I had mine on a day and it began to whine. When i opened the hood, the line had got weak and closed shut. if you have your stock box let me know and i will get some pics
Old Aug 8, 2007 | 05:25 AM
STILL GH3TtO's Avatar
STILL GH3TtO
How does a catch can get installed...And is it needed if you are plannin to run a 50 trin ball bearing kit.... or is itfor non ball bearing??
Old Aug 8, 2007 | 07:42 AM
redevil's Avatar
redevil
lol catch can is a must, no matter what kind and size turbo you got.Tyler, dont use the hose that came with the cc, go to autozone or an autoparts store and buy fuel lines....wich are a lot bettet...that clear hose will not stand the heat of the engine.Come down this thursday and I'll put it on for you, or show you how.
Old Aug 8, 2007 | 09:08 AM
Burnnout's Avatar
Burnnout
I have my greddy catch can mounted on the battery tray bolt.....piece of cake, takes 2 minutes.
Old Aug 8, 2007 | 12:24 PM
MEandmySRT's Avatar
MEandmySRT
might try the center bolt at bottom of the battery tray. that's where i mounted my alta/perrin tank for the breather vent.
Old Aug 8, 2007 | 02:15 PM
Burnnout's Avatar
Burnnout
Is there an echo in here ??? [8D]
