Stage 1 and pods
Old Aug 13, 2007 | 12:50 AM
BLKSRT4's Avatar
BLKSRT4
Default Stage 1 and pods
Ok i just bought a stage one from a friend of mine. and i alsoo bought some gauges and pods. and i was wondering if some one or alof of you can tell me how to install the stage 1 and the pods. or should i just have a professionaldo this
Old Aug 13, 2007 | 01:42 AM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 1 and pods
the s1 is three bolts that hold in the bracket. take them out, swap ecu's and put it back in. your ecu sits behind the driver's side headlight.
the gauges and pods are a little more complicated, mostly because you didn't say what gauges you have and what kind of pods you have.
Old Aug 13, 2007 | 08:25 AM
srt4ever's Avatar
srt4ever
Kind of off topic, but with Stage 1 what kind of gas mileage can I expect, and is the exhaust louder or not? Mine is a 2004 SRT-4.
Old Aug 13, 2007 | 09:52 AM
PSI Chick's Avatar
PSI Chick
the same gas mileage and the exhaust gets a little louder. more popping.
Old Aug 13, 2007 | 01:14 PM
srt4ever's Avatar
srt4ever
Thanks for the help on it, with the Stage 1....1 more question if I may....
Is their a BIG difference in performance with the Stage One, or is it just pretty so-so? And is the exhaust note noticeably louder?
Old Aug 13, 2007 | 02:38 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
It's not a kick in the pants type of power increase. As for the pops, they happen when you take your foot off the gas, especially when going downhill........
Dusty
Old Aug 13, 2007 | 03:42 PM
srt4ever's Avatar
srt4ever
Last question, on it I promise....
Is it worth the 400 bucks for it or not? Can I acheive the same effect with bolt-ons for cheaper?
Old Aug 13, 2007 | 04:02 PM
Burnnout's Avatar
Burnnout
Stage 1 is def. a platform mod .... it makes life way easier for you in the longrun. I would try to find one used though.... it's not an abnormal thing to find.
Old Aug 13, 2007 | 04:14 PM
srt4ever's Avatar
srt4ever
Thanks for all the info...and if someone has a used Stage 1...I'm more than interested in it!!!!!!!!!!!!!!!!!!!!!!.
Old Aug 13, 2007 | 05:20 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Check eBay.......
Dusty
