boost
Old Aug 22, 2007 | 11:05 PM
davanzojga's Avatar
davanzojga
Default boost
just wondering if anyone has had this problem when the boost controller is completely closed my car will boost to 15psi and won't go down till i let of the gas. but if i open the boost controller it will go to 17psi but it starts to drop down after 4500 rpms feels like turbo stops spooling is it normal or is there a problem
Old Aug 23, 2007 | 01:54 AM
PSI Chick's Avatar
PSI Chick
Default RE: boost
sounds like your wga is set too high
Old Aug 23, 2007 | 12:48 PM
davanzojga's Avatar
davanzojga
Default RE: boost
what exactly is it doing
Old Aug 23, 2007 | 01:34 PM
PSI Chick's Avatar
PSI Chick
Default RE: boost
what do you mean?
Old Aug 23, 2007 | 07:44 PM
davanzojga's Avatar
davanzojga
Default RE: boost
is the turbo still spinning or is it spinning backwards
Old Aug 24, 2007 | 02:03 AM
PSI Chick's Avatar
PSI Chick
Default RE: boost
backwards? huh?
just turn your wga down
