tranny fluid help
Old Aug 25, 2007 | 11:15 PM
MAssSrTdriven's Avatar
MAssSrTdriven
Default tranny fluid help
i took the tranny out and need to know the best fluid to fill it with? and how much? thanks
Old Aug 26, 2007 | 12:28 PM
PSI Chick's Avatar
PSI Chick
Default RE: tranny fluid help
mopar af+4 and a bottle of friction modifier, about $20 at the dealer.
i find that the atock fluid is cheaper and perfectly fine, and it should be changed frequently enough that it shouldn't be breaking down anyway.
Old Aug 26, 2007 | 10:05 PM
MAssSrTdriven
did you mean atf+4? and why does this transmission use automatic tranny fluid????? about how much do i put in the transmission. i just emptied it thru the drain plug and pulled the tranny out. so it should be rather empty.
Old Aug 26, 2007 | 10:47 PM
tyler819's Avatar
tyler819
it takes about 2.3-2.5qts of atf+4along with the 4oz bottle of mopar friction modifier
Old Aug 27, 2007 | 01:20 AM
PSI Chick's Avatar
PSI Chick
yea atf apparnetly the "t" didn't type lol
our trannys are designed to use auto tranny fluid, it's easier for mother mopar to use the same fluid in all transmissions than to use gear oil in some and atf in others.
Old Aug 27, 2007 | 02:39 AM
MAssSrTdriven
so how much should i add for fluid? 2.5 seems a bit low?
Old Aug 27, 2007 | 11:55 AM
PSI Chick's Avatar
PSI Chick
nope that's what it takes.
Old Sep 5, 2007 | 08:31 AM
MAssSrTdriven
so i went to a dodge dealer this morning to pick up tranny fluid and the friction modifier. well they tell me my tranny takes a gallon of fluid and there is no such friction modifier that they sell. so now im completly confused....because they said they dont sell a "friction modifier" and that i shouldnt be adding anything to the atf+4 because it ruis the fluid.
Old Sep 5, 2007 | 08:59 AM
PSI Chick's Avatar
PSI Chick
your dealer is a retard. go somewhere else or just tell them to give you what you want and that they're idiots. you need three quarts of atf+4 and a bottle of friction modifier (try "lsd additive", sometimes they understand that better).
Old Sep 5, 2007 | 09:44 AM
MAssSrTdriven
can i buy this friction modifier anywhere else? is there a name brand all the dodge dealers are quite a drive from my house and with my work schedual i dont have the time to make these trips frequently. i plan on putting my car back together sat. once i get this friction modifier, and figure out where all the lines run from my solenoids lol.
