stock motor?
Old Aug 27, 2007 | 11:38 PM
Kapitald's Avatar
Kapitald
Default stock motor?
Hey guys what can the stock motor handle...I know the motor is good for 400-500hp and the stock turbo good for 20psi and no more.....but is there a boost limiter on the stock computer and if so at what psi does it cut out?? is the psi from the turbo limited by the fuel system...like must upgrade the injectors before running 20 psi?? when would you want to upgrade to je pistons or eagle rods.....??
thats a few questions i got...thanks for any help or replies...
Old Aug 27, 2007 | 11:55 PM
Kapitald's Avatar
Kapitald
Default RE: stock motor?
i also found a two small leaks of transmission fluid....one around my differential housing and the other coming from one of the bolts....i tightened up alot of the bolts on the transmission hoping that would help but probly not.....i aint got the money for this right now...lol
Old Aug 28, 2007 | 08:27 AM
Burnnout's Avatar
Burnnout
The stock motor can hold 400-450hp without upgrading to forged parts......the stock ecu will throw an overboost code and pull timing over 16psi...... yes you need more fuel before you turn up the boost, you need a wideband to keep track of your afr's and keep them at 11.5-11.7.
Old Aug 28, 2007 | 11:39 PM
Kapitald's Avatar
Kapitald
hmm....my air/fuel gauge reads anywhere from 14 to 15 in gear driving with low throttle.....WOT it drops to...ive seen 13 and 12 but havent paid enough attention yet...i need to see if the injectors in the car are already upgraded...
Old Aug 28, 2007 | 11:48 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
If it's a 2004, it will have the larger injectors from the factory.....
Dusty
Old Aug 29, 2007 | 01:28 AM
PSI Chick's Avatar
PSI Chick
turn your boost down. now. running that high a/f's at wot is not safe without being tuned for it with race gas.
Old Aug 29, 2007 | 09:00 AM
Burnnout's Avatar
Burnnout
ORIGINAL: Kapitald
When we talk about AFR's we are talking about when at WOT ......you need to take psi chick's advice.
Old Aug 29, 2007 | 02:51 PM
Kapitald's Avatar
Kapitald
well in that case at WOT the car went to 10.3 10.4.....which as i understand is too lean...so im going to adjust my wastegate accordingly and tune the boost down some.....I had to pull part numbers on the car because i dont know what all has been upgraded and what hasnt...(since i just bought it and somebody threw alot of mods on it)....it has the stock 04 577cc injectors and im pretty sure the stock pcm....
what should the afr's be just driving around town not boosting???
Old Aug 29, 2007 | 03:56 PM
Burnnout's Avatar
Burnnout
10's means you are running rich bro. You want to be around 11.5.
Old Aug 30, 2007 | 09:24 AM
Kapitald's Avatar
Kapitald
oh...i see.....10 parts air for one part fuel......hm.....i lowered my wastegate as far as possible and im still running 10.8 and then sometimes it goes to 11.....a lil bit better....
