"Ghetto" OCC!!!
Old Jan 11, 2005 | 06:18 PM
  #41
Black SRT's Avatar
Black SRT
Default RE: "Ghetto" OCC!!!
Well it's in. It's a tight fit. I need to get longer hoses, I used the old ones.
Old Jan 11, 2005 | 07:57 PM
  #42
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yeah, the new hoses are only a couple of dollars. BTW, the little arrow on the top of the OCC needs to be facing towards the throttle body (in the direction of the flow from the PCV valve to the throttle body)......
Old Jan 11, 2005 | 10:50 PM
  #43
Black SRT's Avatar
Black SRT
Yeh, I know they're on right, it just looks that way to make the hoses fit.
Old Jan 11, 2005 | 11:32 PM
  #44
dustyloins's Avatar
dustyloins
Hall of Fame Member
Cool. Let us know how often you have to empty it and what, if any, residue you get in the bottom of the can....
Old Jan 11, 2005 | 11:46 PM
  #45
Black SRT's Avatar
Black SRT
Are you talking about the white stuff? If you are you have a leak. I never had any white stuff in mine until the bowl cracked. Thats the main reasion I got this one, much thicker plastic. Here is what it should look like.
Old Mar 14, 2005 | 07:53 PM
  #46
Black SRT's Avatar
Black SRT
ORIGINAL: dustyloins
How about an update. Well no leaks, and I drain it about once a month, I could go longer. I really think this one is much better that the $20 one. For the main reasion if you forget to drain it is't going to get too full.
Old Mar 15, 2005 | 10:10 PM
  #47
Dodge4SRT's Avatar
Dodge4SRT
Not bad, I'll have to look into it. [sm=signs003.gif]
Old Mar 17, 2005 | 08:55 AM
  #48
71RoadRunner's Avatar
71RoadRunner
One of my OCC's, the PCV one, has milky oil in it from the cold. The condensation from the repeated heating and cooling mixing with the oil makes a lovely milky mix.
Old May 7, 2007 | 04:52 PM
  #49
03srt4's Avatar
03srt4
my getto catch can works great why spend all kinds of money on something that just catches oil for you { like the greedy for $70 bucks thats a rip} I wouldnt spend no more then twenty on it
