Stage 4
Old Sep 11, 2007 | 12:14 AM
BLKSRT4's Avatar
BLKSRT4
Default Stage 4
OK IM Trying to get this right and i know ive posted about this before but i have some more questions.
If i were to buy the stage 4 an install a stage 1 pcm with it would i be able to install an drive or would it need to be tuned and then i can drive through all weather and everything? cause it seems more resonable to buy the stage 4 than the stage 3. cause you get more with it an everything
Old Sep 11, 2007 | 01:20 AM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 4
you get the same thing with either s3 or s4 pretty much, just a different turbo.
if you're going to get a s4 kit, yes you can use a s1 ecu with it. no you can't just throw it on and drive away. you need to tune it.
Old Sep 11, 2007 | 07:59 AM
Burnnout's Avatar
Burnnout
Default RE: Stage 4
You can drive with the base map on the dtec,it just isn't going to be at its optimal power.
Old Sep 11, 2007 | 12:59 PM
BLKSRT4's Avatar
BLKSRT4
Default RE: Stage 4
alright thats all i needed to know. that just settled what i wanted to get finally. i had to do alot of research an alot of asked questions...stage 4
Old Sep 11, 2007 | 01:39 PM
Burnnout's Avatar
Burnnout
Default RE: Stage 4
Make sure to call them and order.... let them know to hook you up with a DBB 50 trim for the same price.
Old Sep 11, 2007 | 02:54 PM
Moparmatt440's Avatar
Moparmatt440
Default RE: Stage 4
Where can you get a stage 4 from? I'm still triing to figure out what was done to my SRT that I just got
Old Sep 11, 2007 | 09:30 PM
T_U_R_B_O's Avatar
T_U_R_B_O
Default RE: Stage 4
i may sound stuped... but what does dtec stand for
thanks
Old Sep 12, 2007 | 12:17 AM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 4
i don't think dtec stands for anything specifically, it's the name of a fuel controller made by turbo xs.
Old Sep 12, 2007 | 01:25 AM
BLKSRT4's Avatar
BLKSRT4
Default RE: Stage 4
and it looks like a really good option. the stage 4 is from AGP. huh i can call them an get the DBB for the same price as the normal 50 trim? geeze i would have spent 500$ for no reason
Old Sep 12, 2007 | 02:02 AM
DreSRT's Avatar
DreSRT
Default RE: Stage 4
damn there is about to be another big turbo srt in the world.....i need to go big turbo faster than i think but congrats on your decision man
