Winter + SRT-4 = ?
Old Sep 29, 2007 | 01:29 AM
  #21
Pressurecooker's Avatar
Pressurecooker
Default RE: Winter + SRT-4 = ?
Yeah living in MI. like I do, I get a refresher course every November whether I want one or not, and the engine warm ups are mandatory as you cant see out the window till the engine starts making enough heat to defrost it anyway. LOL Everything just sloooowwws down.
Old Sep 29, 2007 | 02:44 PM
  #22
PSI Chick's Avatar
PSI Chick
i'm glad my neon sleeps in the winter lol
all-terrain tires ftw
Old Sep 30, 2007 | 11:15 PM
  #23
dustyloins's Avatar
dustyloins
Hall of Fame Member
Mine has one more season of a warm winter, then it's off to the Rockies only to be traded in on a truck.......
Dusty
Old Oct 1, 2007 | 12:50 AM
  #24
mandylin's Avatar
mandylin
So are the stock 17" wheels ok with a good set of snow tires?
Old Oct 1, 2007 | 11:57 PM
  #25
Pressurecooker
-Mandy-Yeah but you should try to get some steel rims to sacrifice instead of your nice aluminums.
-PSI - I wish I could really do that and this year I plan on driving my truck more, but the truck is old and a little scary and I'll probably end up driving the Neon more than I'd like. I really need to throw some money at the truck.
Old Oct 2, 2007 | 05:06 PM
  #26
s1w8a7n 420's Avatar
s1w8a7n 420
be prepared to spin out a lot and to drive slow with patience because these things absolutely SUCK in the winter. learning from experiences last year, im going to keep my srt in the garage as much as possible.
Old Oct 6, 2007 | 09:29 AM
  #27
flamingpinhead's Avatar
flamingpinhead
Section Moderator
ORIGINAL: mandylin
a set of 15" steelies are pretty cheap. not to mention that 15" snow tires will be alot cheaper than 17" snow tires. Just if you plan on using your rims for summer, i would keep them looking nice and not use them for winter.
as for the car warming up properly. id just say to let it idle a coule minutes to get the oil circulating. just dont go spooling up as soon as you pull out of your driveway. ripping on a cold motor is rather bad for it. not to mention with those skinny *** snow tires youll just be tearing valuable tread off trying to rip on the car. with winter tread youll have to be restrained a little more (even when the roads arent bad)
Old Oct 7, 2007 | 12:51 AM
  #28
PSI Chick's Avatar
PSI Chick
ORIGINAL: s1w8a7n 420
if you havea set of snow tires they most certainly do not. if you try to use the stock tires then honestly you're just asking for it, they're three season tires and not meant to ever be driven in the snow.
Old Oct 7, 2007 | 01:09 PM
  #29
flamingpinhead
Section Moderator
no doubt, my first winter i tried the 'not drive it much' idea. but the two or three times i drove it in snow... it was scary. the damn thing could barely drive across a parking lot, let alone safely make it anywhere
Old Oct 7, 2007 | 08:47 PM
  #30
srt4ever's Avatar
srt4ever
I'm on Pirelli P6's...they are all-season tires..are they any good?
