Stage 3
Old Oct 12, 2007 | 03:31 AM
BLKSRT4's Avatar
BLKSRT4
Default RE: Stage 3
whats the usual limit of a stage 3? what if i get the compressor wheel from ptperformance? and would it be better to get it with out toys or with?
Old Oct 12, 2007 | 08:16 AM
Burnnout's Avatar
Burnnout
Default RE: Stage 3
Do you have any specific goal in mind with your car ? ......
Limit of what ? .... Hp or track times ?
Old Oct 12, 2007 | 02:23 PM
BLKSRT4's Avatar
BLKSRT4
Default RE: Stage 3
no so much as in trak times but, i wanted to be in atleast the 400hp, and that would be it forawhile, cause i need to put some money in my stang
Old Oct 12, 2007 | 02:47 PM
Burnnout's Avatar
Burnnout
Default RE: Stage 3
Psichick dyno'd right at 400whp if I'm not mistaken ...... so if 400whp is all you are looking for then stage3 will do.
Old Oct 12, 2007 | 03:07 PM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 3
if you want 400hp w/s3 you need to tune it
Old Oct 12, 2007 | 03:28 PM
Burnnout's Avatar
Burnnout
Default RE: Stage 3
ORIGINAL: PSI Chick
Which kind of defeats the purpose of buying stage 3.
Old Oct 12, 2007 | 04:28 PM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 3
not really. i like the turbo, it's a very nice set up actually.
but a better alternative now is that the s3 turbo/manifold is availible on its own
Old Oct 13, 2007 | 01:08 PM
DreSRT's Avatar
DreSRT
Default RE: Stage 3
do it get the stage 3
Old Oct 13, 2007 | 07:35 PM
BLKSRT4's Avatar
BLKSRT4
Default RE: Stage 3
then wat would be te point of stage 4 then? should i just buy the stage 3 and then get the compressor wheel and honed intake turbo
Old Oct 15, 2007 | 12:30 AM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 3
stage 4 is a different turbo from a different company
