p 1188 code.
Old Nov 3, 2007 | 01:29 PM
blue_srt4's Avatar
blue_srt4
Default p 1188 code.
is this code common with an aftermarket wastegate? its says its tip sensor performance. i've got 0234, 1188, like 0522 or something.
Old Nov 13, 2007 | 07:34 PM
Moparmatt440's Avatar
Moparmatt440
Default RE: p 1188 code.
I have a aftermarket waste gate to and I also keep getting the 1188 and 0234, all I do is just keep clearing them, I have also wrote before about this same 2 codes and the only real way to get rid of them is by a stage kit
Old Nov 13, 2007 | 10:18 PM
faststage02005's Avatar
faststage02005
you can disconnect the pink line on the upper intercooler pipe and cap it off...this will prevent the computer from seen overboost...it only works on 03 and 04....
Old Nov 14, 2007 | 08:44 AM
Burnnout's Avatar
Burnnout
The pink line ? .... that line is for the stock surge valve.
Old Nov 14, 2007 | 09:30 AM
faststage02005
my bad.the red line on the upper pipe..
