PLUGS
Old Nov 17, 2004 | 02:12 AM
kick@$$SRT4nicNcat's Avatar
kick@$$SRT4nicNcat
From: I'm Still In So Cal/He Is In SIERRA VISTA ARIZONA
Default PLUGS
Hey, I seen the question about NGK's so, I thought I'd ask if any of you run SPLIT FIRES or BAUSH PLATINUMS??? If so, how do you like em' and do you recomend em'???
~ I'm Smiling But, I Don't Care ~
[IMG]local://upfiles/8970/0121A2707E124FE0B5C38F39D406E75A.jpg[/IMG]
Old Nov 17, 2004 | 04:42 PM
RIPSIGUY's Avatar
RIPSIGUY
Default RE: PLUGS
From my own experience, trust me on this, if it dont come with platinum from the factory, DONT use em. The only thing Chrysler motors run good on are Champions, or NGK"S. I see cars come in the dealership all the time with
autolites, bosch, etc. They run like crap. Platinum's advantage is slower gap change over time. They foul if you just look at them the wrong way, and they are expensive. You dont get any more power from them.
Old Nov 23, 2004 | 03:28 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: PLUGS
Splitfires or most other heavily advertised "miracle HP gains" almost never deliver what they promise. If they did, everyone would be using them. And everyone isn't.
Old Nov 24, 2004 | 03:20 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: PLUGS
That's right, and that is why I stick to my Champions, I've tried several others and have never noticed a difference. When the 400 in my Roadrunner went south it started oil fouling plugs and the Splitfires did take a little longer to oil foul than the other brands, but they still did eventually foul out.
Old Nov 24, 2004 | 12:07 PM
PSI Chick's Avatar
PSI Chick
Default RE: PLUGS
champions, ngk's, or densos are all that should really be in these cars. the densos do seem to work the best, but are the most expensive.
