A few things to check would be. First try to adjust the pedal. there is an 8mm screw that u will see if you behind the clutch pedal that is attaches the pedal to the clutch rod. Try to adjust that so the pedal is all the way up. IF that doesnt work make sure you have enough fluid in the hydraulic system. If that doesnt work if your on an aftermarket clutch i would make sure that the bolts on the pressure plate are tight. If that isnt it. It is either your slave cylinder or maybe air in the system. Did you do anything to the clutch or the hydrolic system
if you have the money and ur still on a stock clutch or just a clutch thats weared out already get another one since their goin to pull out the tranny...thats what i did...
