Ran a 13.8 first time out and cracked the oil pan
Old Nov 23, 2004 | 06:15 PM
Black04's Avatar
Black04
Default Ran a 13.8 first time out and cracked the oil pan
Well went to the track ran a 13.81 and was told to slow down or get a helment BOOOOO
on the run befor that got a nasty wheel hope (took off at 1500 RPMS too) so bad the windshild wipers came on and the motor mount under the passanger up front hit the oil pan?? CRAZY but it did put a dent in it and cracked it. The Half shaft hit the cross member and riped the boot.
Is this why I need to change the motor mounts??? My friends were in the stand taping it you can here it on the tape in the stands IT WAS NASTY I will try like hell to get it on the computer so you can here it[&:]
Old Nov 23, 2004 | 06:46 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Ran a 13.8 first time out and cracked the oil pan
Yeah, the tape would be very interesting....
Old Nov 23, 2004 | 06:47 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
umm...yeah.
Old Nov 23, 2004 | 07:12 PM
Bruins013's Avatar
Bruins013
how the hell...the motor mount wasnt that close to the oil pan last time i was under there, but get some motor mounts, they will help ya
Old Nov 23, 2004 | 07:26 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
My thoughts as well, but some digi cam pix will solve the mystery.......
Old Nov 23, 2004 | 10:16 PM
Gump's Avatar
Gump
yeah my windshild wipers come on almost everytime i run at the track lol. well on the ones with wheel hop. i think i got rid of it now but its all rainy here so no track.
Old Nov 23, 2004 | 10:56 PM
LilSparkPlug's Avatar
LilSparkPlug
Yeah ummmm motor mounts aren't near the oilpan darling. Did you lower your car as much as your last car??? That might do it you know. And you shouldn't need solid motor mounts at a 13.8, they aren't a neccessity at that speed, but they do help. It sounds like you didn't know what the hell you were doing to cause that type of damage to the vehicle.
I don't believe for a second that they even let you run under 14 seconds without a helmet. Its a law up here in the Northeast, at NED that you HAVE to have a helmet under 14 seconds, and under 11 you need a full race rollcage.
And if the motor mount fell off the only way I can think that you cracked your oilpan is that your engine completely dropped when that occured. Your motor mount persay would not crack the oilpan. But breaking the motor mount could, if you really really were bangin it hard. And even then..its damn hard. This kid Ben (Bruins013) and I know, dumped EVERY mount in his engine but one....and didn't crack his oilpan.
Motor mounts are putting tension on areas of the car that can't support it all that well, and the motor mounts are not made for severe conditions. If your really gonna beat the hell out of it, get some inserts, or pop in some solid mounts.
For someone who's claiming to make their own exhaust, DP and Intercooler....doesn't seem like you know too much about this car, if you don't realize that you need motor mounts. Research things more.....before the poor car gets murdered.
Old Nov 24, 2004 | 12:09 AM
Bruins013's Avatar
Bruins013
Newman is that u? i thought u were only going 5 mph j/k (inside joke)
your car is not in good shape if u cracked the oil pan, cause that is not easy...
Old Nov 24, 2004 | 04:35 AM
LilSparkPlug
ORIGINAL: Bruins013
NEWMAN?!?!?! Must've been in first gear at 5mph that this happened, and your engine mustve fell RIGHT out of the bay breaking every mount in sight.... Did your radio do this too Newman??? (inside joke)
I think i found a picture of the damage....LOL!!!
Black04 we aren't picking on you, it just reminded us of an inside joke, Paul knows too.
"I THINK ITS BROKEN!"
[IMG]local://upfiles/8899/DC74E11AAF6540249A2AF03C96967937.jpg[/IMG]
[IMG]local://upfiles/8899/ECF8C6FF030A4BAB8A9668EE16587655.jpg[/IMG]
Old Nov 24, 2004 | 05:39 AM
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: BadStratRT
umm...yeah.
I second that.[sm=rolleyes.gif]
