NEED SOME SERIOUS HELP
Old Dec 5, 2007 | 01:56 AM
tuca's Avatar
tuca
Default NEED SOME SERIOUS HELP
having problems with my srt-4 hope you guys and girls can help me out.
when i pedal to the metal car will just back fire really loud and car wont run at all.
i also noticed there was i lot of oil in the intercooler piping (is that normal)? i cleaned out the oil and now the boost wont pass 7psi.
car will just bug out.
Old Dec 5, 2007 | 08:44 AM
Burnnout's Avatar
Burnnout
Default RE: NEED SOME SERIOUS HELP
"now the boost wont pass 7psi"
Boostleak, when's the last time you changed your plugs/wires ?
Old Dec 5, 2007 | 09:36 AM
faststage02005's Avatar
faststage02005
check your fuel pump...[&:]
Old Dec 5, 2007 | 09:37 AM
PSI Chick's Avatar
PSI Chick
define "bug out"
Old Dec 5, 2007 | 05:21 PM
the beast14's Avatar
the beast14
the same thing is happening to me and i still dont know what it is let me know if u find out what it is
Old Dec 6, 2007 | 12:39 AM
tuca's Avatar
tuca
i havent changed the plugs and wires since i got the car( a year ago)
Old Dec 6, 2007 | 12:43 AM
tuca's Avatar
tuca
i dont think is a boost leak cause it was working fine before. after i cleaned out the oil from the cold pipe is started f#$%@ing up
Old Dec 6, 2007 | 12:45 AM
tuca's Avatar
tuca
Bug out= floor the gas pedal car wont move at all just back fire( i can feel back fire under my feet really strong)
Old Dec 6, 2007 | 08:27 AM
Burnnout's Avatar
Burnnout
You probably are leaking from the cold pipe you took off then.....and you really should change your plugs and wires.
Oh and the edit button is your friend.
Old Dec 6, 2007 | 04:31 PM
daporkchop03's Avatar
daporkchop03
yea change ur coil spark plugs nd wires.. same shyt happeneed to mine nd it runs right now
