Question for the pro's
Old Nov 29, 2004 | 11:17 AM
Dodge4SRT's Avatar
Dodge4SRT
Default Question for the pro's
Just curious, I have a 2004 SRT-4, I used to be able to get 11-14 PSI of boost, now I only get 5-9 PSI???? Very confused?? [sm=dontgetit.gif] I appreciate if someone can explain this to me. Thanks.
Old Nov 29, 2004 | 11:19 AM
Dark Syde SRT4's Avatar
Dark Syde SRT4
Default RE: Question for the pro's
what weather conditions are you in? fuel are you using, are you throwing any codes? let me know...if i cant help im sure the guys on www.srtforums.com
Old Nov 29, 2004 | 11:32 AM
Bruins013's Avatar
Bruins013
weather...u will lose like 2 psi as it gets colder...
but your looks like a bigger than 2 psi drop...
u completely stock? u could have a leak also
Old Nov 29, 2004 | 11:53 AM
Dodge4SRT's Avatar
Dodge4SRT
It is all stock except for a Mopar BOV. I use 93 octane in it. The tank I just put in, I threw in 94 to see if it does any difference. I live right outside of Philadelphia, Pennsylvania. The temperatures are 40's to 50's. [sm=smiley22.gif]
Old Nov 29, 2004 | 12:59 PM
Gump's Avatar
Gump
did you put sealant on the BOV seal?
Old Nov 29, 2004 | 02:39 PM
Dodge4SRT's Avatar
Dodge4SRT
This happened before the BOV was installed, not sure if it could be the gas I'm getting or what?? I do have a rattle that seems to come from the engine compartment up by where the front defroster is, others seem to say they have that also, and said it was gas related. I'm just confused.
Old Nov 29, 2004 | 02:53 PM
PSI Chick's Avatar
PSI Chick
check for boost leaks......
Old Nov 29, 2004 | 02:54 PM
TurboPowered's Avatar
TurboPowered
You may want to try another gas station
Old Nov 29, 2004 | 03:01 PM
coyoteyz13's Avatar
coyoteyz13
If it is still under warranty, take it in.
Old Nov 29, 2004 | 03:30 PM
posthondaremoval's Avatar
posthondaremoval
Where are you at - I live in Ardmore. I wouldn't think you are having a Gas problem. Although it's pretty expensive around here it's all pretty good as long as you go to a good stn. like Sunoco and not Hess or something.
Let us know what it turns out to be. I'd say you need to find a good dealer - and it's tough around here. I just found Bergey's in Lansdale. It's not too far and they have a mechanic with stage 3r. They are into the SRT-4 and most around here don't have a clue.
I would talk to the guys up there and see if they could get you in to see Jason (Their 3R guy). Also check your intercooler hoses, and any vaccum lines for a leak.
Do you have an increase in rpm's at idle?
