Just wondering for all you that have a oil pressure gauge, I put my sender on a T with the factory sensor but I found out tonight that it is starting to leak, is there another place that I can tap into a oil galley for the sender? Where are you installing them?
So just take out one of those allen head caps and put it into there, cool I didnt really like that spot but it worked great on my SXT. It was reading pretty good I thought at WOT I was hitting 75 psi, I have a 100 psi gauge, then at stop it woudl drop down to 25 psi, are these the same numbers you get?
Got it all switched, my gauge is now on the side of the head, And your right PSI Chick now I have different reading not much, WOT im getting 50 psi. How hi of a sender/ gauge do you have?
