Max Boost Stock?
Old Dec 20, 2007 | 09:04 AM
04blusrt4's Avatar
04blusrt4
Default Max Boost Stock?
What is the max "safe" boost to run on a completely stock setup? And what is the best way to acheive the increased boost with a stock setup? (i.e. controller, waste gate, etc.). Best brands?
Thanks!
Old Dec 20, 2007 | 09:38 AM
PSI Chick's Avatar
PSI Chick
Default RE: Max Boost Stock?
15 or 16 psi about. any wga/mbc combo will work really.
Old Dec 20, 2007 | 10:33 AM
04blusrt4's Avatar
04blusrt4
any recommendation for which? Sorry, really new, want to make the best choice.
Old Dec 20, 2007 | 01:32 PM
PSI Chick's Avatar
PSI Chick
agp wga is a good choice and easy to tune. for a mbc, i have a kinetic and have no complaints. the turbo xs one is good too.
Old Dec 20, 2007 | 01:36 PM
808srt's Avatar
808srt
what would be the best way to set up wga/mbc isnt it like you set your mbc to around 12 and then your wga to about 16 or am i not even close
Old Dec 20, 2007 | 02:32 PM
Burnnout's Avatar
Burnnout
Other way around.
Old Dec 20, 2007 | 06:13 PM
808srt's Avatar
808srt
i dont understand why you would set your mbg to 16 and your wga to 16 cause i onlyu have a wga that is set at around 15-16 and does a mbc realy do that much of a differance like something one would notice
Old Dec 21, 2007 | 09:26 AM
PSI Chick's Avatar
PSI Chick
yes it does. i don't know why people on this board are so anti-mbc. using a mbc with a wga reduces ptb and also helps control drop off of boost.
Old Dec 21, 2007 | 01:39 PM
808srt's Avatar
808srt
so you do set your mbc at a higher psi then your wga
Old Dec 21, 2007 | 01:47 PM
Burnnout's Avatar
Burnnout
Yes.
