what is a wideband
Old Dec 26, 2007 | 12:40 AM
the beast14's Avatar
the beast14
Default what is a wideband
What is a wideband and what does it do and when should I buy one. My mods r agp fmic, intake, 3' exhaust, wastegate set at 16psi dropping down to 10, act clutch, nitrous intercooler sprayer, and downpipe.
Old Dec 26, 2007 | 08:41 AM
Burnnout's Avatar
Burnnout
Default RE: what is a wideband
A wideband is a gauge that uses a wideband o2 sensor to display your air/fuel ratio's.Before you change your stock boost levels you should get one.
Old Dec 26, 2007 | 11:23 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
yes, you have a wastegate and can 'play' with your boost levels. you definately need a way to monitor your a/f ratios.
Old Dec 26, 2007 | 12:06 PM
the beast14
What should b my a/f ratios
Old Dec 26, 2007 | 12:10 PM
PSI Chick's Avatar
PSI Chick
no more than around 11.5-11.7 at wot
Old Jan 4, 2008 | 12:25 AM
808srt's Avatar
808srt
so say that you have a wideband to monitor your a/f ratio so if it is runing rich or lean what are you suppose to do about that or does the the gauge take care of that for you and if i were to get one which would be a good one to get
Old Jan 4, 2008 | 01:24 AM
PSI Chick's Avatar
PSI Chick
if it's running rich you pull some fuel, if it's running lean you turn down the boost. the gauge doesn't do anything for you other than read your a/f's, you need a tuner to control fuel to tune properly.
Old Jan 4, 2008 | 04:49 PM
808srt's Avatar
808srt
"pull some fuel"? and what kind of wideband would you recomend and what kind of controler are th ones agp sells good because i live kinda close to them and it would be the easiest and cheapest way to go.
Old Jan 4, 2008 | 05:59 PM
PSI Chick's Avatar
PSI Chick
pull fuel, as in there isn't as much fuel going to your injectors.
the best on the market are the innovate and the aem. they're the two most common ones. the innovate is more expensive than the aem but it does more. as for a controller, a dtec fcor a safc-neo are the most common.
