SRT Calipers
Old Dec 27, 2007 | 01:08 PM
Flash_Gordon2392's Avatar
Flash_Gordon2392
Default SRT Calipers
Goodmorning,I have a question to ask of you SRT forum members,and I hope that you could help me with this.As you know I own a 04 Neon SXT.I want to upgrade my brake system from stock and use a performance system on my brakes.[sm=feedback.gif][:@][sm=feedback.gif]I call and sent email to so many companies,and I also bought the ultimate buyers guide the other day.And that's no luck.Could someone help me out?I am about to pull out what little hair I have on my head[sm=feedback.gif][:@][sm=feedback.gif]
Old Dec 27, 2007 | 03:00 PM
srt4ever's Avatar
srt4ever
Default RE: SRT Calipers
I am a little unsure, but I would say the SRT Calipers would fit...but
- Clearance issues would be a problem, I am sure bigger rims would be needed
- I know that SRT's have upgraded knuckles and such, yours dont..you may have
issues in that area as well.
Sorry, I cant help more than that...othrs..I'm sure will chime in and help...
Old Dec 27, 2007 | 03:40 PM
Flash_Gordon2392
Well,I am upgrading my rims from stock rims.In to a 17x7 this spring.I hope!But clould I please ask you this.Do you know the part number for the front and rear calipers?
http://i141.photobucket.com/albums/r...1183587439.jpg
Old Dec 27, 2007 | 07:29 PM
Moparmatt440's Avatar
Moparmatt440
When I had my 04 SXT I put on the rear SRT-4 brake assembly with no prob, and I had stock 15 inch rims. I don't think that there is an issue with clearance even on the front, as long as you have 15 inch rims you should be okay. I have seen the brake calipers on ebay quite a bit, for the rear if you wanted to have the disc's you would need the whole assembly like I got and put on also found on ebay.
Old Dec 27, 2007 | 08:57 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
the stock SRT4 front brakes will barely fit into a 15" rim. im running 15 steelies for the winter, dont recall the offset though, but they have just a hair of clearance over the brakes. but youll likely need whole thing out of an srt4 to use the larger srt brakes.
Old Dec 28, 2007 | 01:08 AM
PSI Chick's Avatar
PSI Chick
as long as the offset is ok on the 15's it shouldn't be a problem. i have 15x7's with a +35mm for my slicks and i have tons of room between the caliper and the rim. it all depends on the rim really.
Old Dec 28, 2007 | 01:49 PM
Flash_Gordon2392
ORIGINAL: flamingpinhead
Well,I went to one of my dealershipslast night.I have the part numbers for the front and rear calipers,but again they dont know if it's really doing to work or not![sm=lame.gif][sm=icon_blah.gif][sm=icon_blah.gif][sm=lame.gif]And they are telling me that they dont deal with modification's,they just deal with factory parts.And I shouldn't listen to whatother people are saying on this forum[sm=lame.gif][sm=icon_blah.gif][sm=icon_blah.gif][sm=lame.gif],I just told them to have a nice day and walked (the "F______") out the door.Where can I order them at?Could I get them from www.dodgeparts.com or www.oemdodgeparts.com ?And can I get them in yellow? And do I really have a choice?
Old Dec 28, 2007 | 02:02 PM
PSI Chick's Avatar
PSI Chick
they only come in red, but you can paint them, that's nota big deal. try ebay or something for calipers, it will be cheaper.
Old Dec 28, 2007 | 02:03 PM
Flash_Gordon2392
[sm=confused06.gif]And do I have to change my knockles as well[sm=confused06.gif]?Because I do have the part numbers.
Old Dec 28, 2007 | 07:08 PM
Moparmatt440
For the rears you will need to get the whole setup, disc + calipers + backing plate + and SRT-4 E-brake cables, I think that the ones on the SRT are a bit longer then the SXT ones, the hibs cross over from your SXT to the SRT rear disc brake set up. Just look on Ebay that where I get mine, the fronts should bolt up, you might need the mounting bracket from a SRT for the front. I just did the rear on my SXT before I traded it in for a SRT
