Trouble at 2700 RPM?
Old Jan 17, 2008 | 09:01 PM
blackacr's Avatar
blackacr
Default RE: Trouble at 2700 RPM?
are they the denso wires?
Old Jan 17, 2008 | 09:03 PM
faststage02005's Avatar
faststage02005
also if that dont work check the lower intercooler piping...my friends was doin something similar....have somebody rev the car and check it out....because the pipe wasnt expanding it was getting suck together... [:@]
Old Jan 17, 2008 | 09:23 PM
blackacr's Avatar
blackacr
K, cool, thanks for the input. I'll check it out.
Old Jan 17, 2008 | 10:16 PM
71RoadRunner's Avatar
71RoadRunner
A bad coil pack can do really weird things too, so you might want to check it as well.
Old Jan 18, 2008 | 11:05 AM
PSI Chick's Avatar
PSI Chick
ORIGINAL: blackacr
yes
blackacr's Avatar
blackacr
I pulled the front brace off and I still havethe problem. So now I'll have to look into a new coilpack or check my IC pipes. What is a good replacement for the stock coilpack? Accel, Screamin Deamons, MSD, stock...???I noticed the stock ones are pretty pricy compared to Modernperformance's MSD Pack.
Old Jan 18, 2008 | 01:34 PM
Moparmatt440's Avatar
Moparmatt440
Everyone one here says to stick to the stock one, that the MSD and others dont really do that much, and I even looked into it and the MSD puts out the same volts as the stock one, kinda weird I thought so I think everyone is sticking with a stock.
Old Jan 18, 2008 | 05:54 PM
drewthatsmenb's Avatar
drewthatsmenb
my car had this flutter problem before i upgraded the turbo only it didn't just do it at 2000 to 3200 rpm it did it threw out the gear it was peaking at 15 and holding at 13 i thaught it was b/c of the stock wastegate but i'm not really sure what the problem was the car wasn't modiefyed at all when it was happening.
Old Apr 22, 2008 | 06:19 PM
blackacr's Avatar
blackacr
I'm digging up an old thread here but here is what I've tried so far to attempt to resolve this issue... I've tried going back to OE wires, and back to my MSD's, which are pretty new. I've also tried removing my strutbrace, and I borrowed a coilpack from another neon, I've tried replacing the plugs 2 times, but I've only tried the LZTR5AIX-13 NGK iridium. not the colder LZTR6AIX-13's. Also tried differentgap on theplugs, currently I'm at.036. I've tried putting the stock surgevalve back on to see if the BOV was letting boost by. (I have the Boomba BOV which mounts to the compressor housing) I've gone to my local tuner shop and asked about them aboutit and they think is is definitaly a ignition issue due to the problem is happening at the SRT's peektorque curve. does anybody think switching to the colder NGK's may help at all or have any other suggestions? thanks all for any input.
Old Apr 22, 2008 | 06:36 PM
Plan B's Avatar
Plan B
You shouldn't need to go colder at your boost levels, those NGKs should be fine. maybe try a set of the champions (they're pretty cheap) and gap them from .50 and move down. Have you boost leak checked your car recently?
My buddies MSD wires were sparking bad as well. Shocked a couple people when we were throwing the rpm sensor over the coil on our last dyno day lol
