Signs your stock clutch is going bad...if any?
Old Jan 28, 2008 | 02:18 PM
srt4ever's Avatar
srt4ever
Default Signs your stock clutch is going bad...if any?
Just like it says, when is it time for one, and when is it starting to go...?
Old Jan 28, 2008 | 04:35 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Signs your stock clutch is going bad...if any?
I knew my SRT Ram clutch was toast when I had smoke everywhere on take offand it was not the tires making the smoke
You can also smell it burning a little in the early stages. Takes more RPMs to get the car to launch at the same power as earlier launches (ie the clutch is slipping and you need more power to get the same feel out of the hole).
Old Jan 28, 2008 | 09:13 PM
srtgtr34's Avatar
srtgtr34
how much was the clutch for that srt10?
Old Jan 28, 2008 | 11:03 PM
PSI Chick's Avatar
PSI Chick
when you drive and push on the gas and your rpms increase but you're not going any faster it's time for a new clutch
Old Jan 29, 2008 | 08:11 AM
srt4ever's Avatar
srt4ever
Thanks everyone
Old Jan 29, 2008 | 09:46 AM
CarGuyOhio's Avatar
CarGuyOhio
I bought more than a clutch.
I boughta new Centerforce clutch, light weight flywheel, upgraded slave and master cylinders, it was just under $1500.
Old Jan 29, 2008 | 01:00 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
ORIGINAL: 94rt10ohio
i once bought an entire car for well under that
Old Jan 29, 2008 | 03:07 PM
srt4ACRboy's Avatar
srt4ACRboy
wat psi. said same thing happened to my beasty saturn
