problem wit my turbo xs rfl bov
Old 01-30-2008, 06:47 PM
daporkchop03's Avatar
daporkchop03
daporkchop03 is offline
Default problem wit my turbo xs rfl bov
i put it on and when i accelerate it makes a screeching noise nd does not do wat it does. it makes a fluttering sound after it .. idk wats wreong with it.. nebody kno
Old 01-30-2008, 07:01 PM
Moparmatt440's Avatar
Moparmatt440
Moparmatt440 is offline
Default RE: problem wit my turbo xs rfl bov
How do you have it adjusted, I have mine two full turn out from the bottom, maybe you need to turn it all the way down then back it off a bit. You sure that the fluttering noise is coming from the bov and its not the surge valve?
Old 01-30-2008, 07:02 PM
daporkchop03
no i have a block off playte on it nd i turned it down a lil idk wat it is
daporkchop03
the flutterin sound comes out of my intake
Old 01-30-2008, 07:13 PM
Moparmatt440
I get the fluttering noise,sounds normal to me, are all the hose clamps tight? try adjusting it down all the way and see if it makes a difference, and if it does then try backing it off a bit say a full turn out.
Old 01-30-2008, 07:30 PM
daporkchop03
ok ima c wat it does.. but when i accerate it makes a screachin sound nd a tiny liek whoosh liek weird
Old 01-30-2008, 08:16 PM
daporkchop03
still the same thing... its gettin me mad lol
Old 01-30-2008, 09:31 PM
Moparmatt440
I know that mine makes a screeching/ whistle noise when I back off the throttle a bit but then is only happens for a sec. Have you check all your clamps maybe its just a boost leak from another pipe hose. Try and write Turbo XS maybe they can tell you a bit more to try.
Old 01-30-2008, 11:44 PM
daporkchop03
like i loosened it and still when i accerate makes a screeching sound then when i let go of the gas it flutters idk wat it is and its makin me ony boosy 12 pounds instead of 18 19
Old 01-31-2008, 05:40 PM
Moparmatt440
sounds more like a boost leak fromsomewhere. Where do you have the hose connected up to, the one on top of the bov,mine is T into the spacer between the tb and the manifold. I would just jack it up and loosen all the hose clamp and re-tighten them
Quick Reply: problem wit my turbo xs rfl bov
