head gasket..
Old Feb 1, 2008 | 08:51 AM
faststage02005's Avatar
faststage02005
Default head gasket..
so im planning on ordering a new head gasket. beacause of the white smoke that shoots out when i go wot and let off.....i heard that i need to buy head studs..is this true???
Old Feb 1, 2008 | 09:38 AM
mopar222's Avatar
mopar222
Default RE: head gasket..
Why don't you go have the cooling system pressure tested, this will tell you if you really do have a bad head gasket. If the system does not hold pressure, it probably is a head gasket, but why jump to conclussions. Pull the spark plugs and look at them, one should look different from the others, another sign of a leak, air bubbles in the coolant resevoir, another sign. Just check it out throughly to make sure that this is the case. Good luck.
Old Feb 1, 2008 | 02:25 PM
srtgtr34's Avatar
srtgtr34
you do not need new head studs they are lieing just get the head gasket, they are trying to get more money out of you.
Old Feb 1, 2008 | 09:16 PM
faststage02005
[&:]can the spark plugs be the problem???
Old Feb 1, 2008 | 11:02 PM
srtgtr34's Avatar
srtgtr34
That would be the first thing you should replace b/c its the cheapest but usually white smoke = head gasket. It doesnt hurt to change them, you should at least check them and make sure they are not fouled out.
