twin turbo your srt?
Old Feb 3, 2008 | 07:25 AM
drewthatsmenb's Avatar
drewthatsmenb
Default twin turbo your srt?
hey guys i was browsing around ebay and i stumbled across this rediculious item i was like [sm=jawdrop.gif]
is this even posible?
http://cgi.ebay.com/ebaymotors/Rare-...spagenameZWDVW
Old Feb 3, 2008 | 08:52 AM
motorboy1's Avatar
motorboy1
Default RE: twin turbo your srt?
real deal. mostly just a novalty setup in my opionion. you can makethesame hp on single turbo way cheaper. But hey you can say you got twins, thats cool.
Old Feb 3, 2008 | 11:31 AM
PSI Chick's Avatar
PSI Chick
600hp is a novelty? i wouldn't do it myself, but it certainly has it's benefits. much faster spool so you don't get the massive lag that you get with big turbos. gt35r's and 60 trim turbos that will make the same power don't spool until 4000-4500 rpms, this set up is closer to 3k. that's a HUGE benefit there. dcr isn't going to just make a kit for the hell of it........
Old Feb 3, 2008 | 06:43 PM
Moparmatt440's Avatar
Moparmatt440
Its not a false part DCR does make it, just look at their web site, I also agree with PSI Chick, it just depends on what you want to do with your SRT, course that set up with two s3 turbos would just be sick but also just get a 60 trim or even a bigger turbo say from turbonetics use a GTK one and make more hp.
Old Feb 3, 2008 | 09:02 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
so put simply, one larger turbo gives you a higher max output of hp at higher RPMs (once it gets going), but the twin turbo wont spike as high at max power, but will be more steady power across the entire RPM range...
Old Feb 3, 2008 | 10:12 PM
drewthatsmenb
i wish i knew about this kit before i bought the 50 trim this kit looks and sounds badass
Old Feb 4, 2008 | 02:51 AM
pssssst's Avatar
pssssst
wow thats pretty sweet
Old Feb 4, 2008 | 09:17 AM
drewthatsmenb
INDEED!
Old Feb 4, 2008 | 03:11 PM
srt4ever's Avatar
srt4ever
I could only imagine the PSSSSSH sound(BOV) you would got outta that...HUGE!!!!!
