car shakes
Old Feb 5, 2008 | 08:56 PM
boostneon's Avatar
boostneon
Default car shakes
my car shakes at around 80 mph, it al started after i changed my passenger axle, i had new tires put on my car, they were balance and i had my car allinged. after all that my car still shake on the freeway, when i hit 80 mph. any i deas of what else i can do to my car.
Old Feb 6, 2008 | 12:54 AM
faststage02005's Avatar
faststage02005
Default RE: car shakes
your lower control bushings can be out causing the alighnment to mess up....
Old Feb 6, 2008 | 01:39 PM
prpaster's Avatar
prpaster
If it is in the steering wheel it is probably the balance of the wheels
Old Feb 6, 2008 | 01:50 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Mine is just the opposite. It likes to wander a little below 40 mph, but the faster it goes, the smoother the ride gets.
Dusty
Old Feb 7, 2008 | 12:19 AM
boostneon's Avatar
boostneon
its not just in the steering wheel, the hole car shakes i can see it on my passenger side seat. could it be the camber bolts i put on? i put them on before the allingment.
Old Feb 8, 2008 | 11:30 PM
drewthatsmenb's Avatar
drewthatsmenb
it could be the balance if they used the weights that stick on to the rim, they love to fly off at speeds of 65+
Old Feb 11, 2008 | 04:52 PM
silverbullett's Avatar
silverbullett
my car shakes at low speeds around 20 to 40 mph and after that it gets better. its comin from my passenger side i replaced my passenger axle and had my tires re-balanced.
Old Feb 16, 2008 | 12:57 AM
boostneon's Avatar
boostneon
same here, i replaced my passangers side axle and after that it started to shake,i had it balanced but notting . i checked every thing from when i replaced the the axle.
Old Feb 16, 2008 | 03:04 PM
sab2007's Avatar
sab2007
You put a crappy axle in.... if it isnt an OEM axle.... it will most likely have issues. Alot of the aftermarket axles I see have issues, and for the most part I try to stick with a few good known manufacturers or OEM
Old Feb 18, 2008 | 10:23 PM
boostneon's Avatar
boostneon
it is an oem i got it from the dodge dealer. may be the shop were i had my alligment done didnt do it right, im goin to take it to the dealer and see how much they'll charge me for an alligment.
