BOV Questions
Old Mar 13, 2008 | 08:00 PM
dparsons06's Avatar
dparsons06
Default BOV Questions
Im thinkingi want to put a Greddy Type RS BOV on my car once i get my transmission settled. What else will i need to buy to put the bov on?
Old Mar 13, 2008 | 09:32 PM
SRT305's Avatar
SRT305
Default RE: BOV Questions
Your gonna need a ATP pressure pipe or just look for flanges that should go with the bov k check out some of the performance websites n you will see k man.
Old Mar 13, 2008 | 09:36 PM
dparsons06's Avatar
dparsons06
Ok thats what i thought, i dont need a Block Plate or w/e there called, some of the sites were sayin i needed them and other werent, so i wasnt sure
Old Mar 13, 2008 | 11:57 PM
drewthatsmenb's Avatar
drewthatsmenb
if your running the stock turbo you will need a block off plateto replace thedeverter vavle
Old Mar 16, 2008 | 03:50 PM
LilSparkPlug's Avatar
LilSparkPlug
You will need a few things:[/align]1. Block off plate for the stock turbo's surge valve. This valve will be removed and the plate will take its place. You can get these at AGP and just about anywhere.[/align]2. A cold side pipe with the proper flange for the Greddy. These are available all over the place, PTP Performance, Modern Performance, BWoody Performance, JMB Performance, AGP, ATP, Exhaust Depot, etc. Don't cheap out, if it hits your slave cylinder your transmission will hate you later.[/align]3. The BOV...obvious But get it from a reputable seller, the knockoffs WILL leak.[/align]4. Couplers. Some pipes come with them others do not. Its best to buy a whole kit like some of the aforementioned vendors sell.[/align] [/align][/align]And use T-Bolt clamps instead of hose clamps. They prevent boost leaks far better, and won't strip as easily as a conventional hose clamp.[/align]
Old Mar 17, 2008 | 03:05 PM
dparsons06's Avatar
dparsons06
Thank you all for your help, ill let you know how it goes wheni buy it and install it
