AGP Dog bone Motor Mount Kit
Old Jan 5, 2005 | 11:36 PM
NeonOrngBlast's Avatar
NeonOrngBlast
Default AGP Dog bone Motor Mount Kit
Is this kit as good as the Boomba Engine Mounts? What do you all think they are cheaper but sometimes you get what you pay for?
Old Jan 6, 2005 | 12:50 AM
glhs837's Avatar
glhs837
Default RE: AGP Dog bone Motor Mount Kit
The Boombas are top quality stuff. I've helped install a set, love'em Do be aware that you will have more vibration.
Old Jan 6, 2005 | 01:03 AM
NeonOrngBlast
Yes i heard that but i hate the wheel hop and would hate to crack the oil pan. If i dont like the way they fell i will switch it back.
Old Jan 6, 2005 | 03:13 AM
Bruins013's Avatar
Bruins013
i just got the boomba...i love them, look nice too
Old Jan 6, 2005 | 03:22 AM
LilSparkPlug's Avatar
LilSparkPlug
Ive been told the mount has nothing to do with cracking the pan, its too far away.
Old Jan 6, 2005 | 05:29 AM
71RoadRunner's Avatar
71RoadRunner
My inserts have helped alot with wheel hop, but I may need to get the solid mounts later to completely eliminate it.
Old Jan 6, 2005 | 10:58 AM
PSI Chick's Avatar
PSI Chick
no motor mount is going to completly eliminate wheel hop. it will help, but it will not make it completly go away.
and sexy is right, wheel hop has nothing to do with cracking the oil pan.
Old Jan 6, 2005 | 01:00 PM
NeonOrngBlast
So why is everybody saying that when they change the lower mount it has left marks on the pan? I will have to get the car up and look for my self. I think i will go for the Boombas.
Old Jan 6, 2005 | 01:07 PM
PSI Chick's Avatar
PSI Chick
2 reasons - 1. because the lower bolt has a habbit of backing out if it's not installed correctly, and i would venture to guess that at least 50% of people don't do it properly. when the bolt backs out the mount can then move, which causes the same issues as seen next.... 2. people with this issue have noticed it mainly with the stock mounts, not aftermarket. the stock mounts are too flexible to handle the power of this car, and as such they bend, a lot. so when they flex they hit into the oil pan. a solid mount will actually prevent this from happening.
this has been a major issue on my car, by lower mount is comepltly torn apart. i'm waiting on a set of dogbones from psi-fi to fix it at the moment.
Old Jan 6, 2005 | 01:15 PM
NeonOrngBlast
ORIGINAL: PSI Chick
So you dont think there is much Difference in the 2 mounts the dog bone is about 70 cheaper?
