Need Help With BOV
Old May 11, 2008 | 01:38 AM
dparsons06's Avatar
dparsons06
Default Need Help With BOV
I installed my greddy type rs bov earlier today and im having a little trouble with it, it only makes a small "swoosh" noise at full throttle and i have tried to adjust the soft and hard settings but I think its how its connected. What do i tie the vacumn line coming off the bov into? i was told to use the pink line that was comin off the stock valve but i have a feeling that isnt right. There is no spotfor the red wire on my UHP so i was told to just take that completly out and cap it off, Is that true?
Old May 11, 2008 | 02:50 AM
srtratblock's Avatar
srtratblock
Default RE: Need Help With BOV
Cap the pink line off and T-off the black line coming off IM above TB. I have the red line hooked up pipe. I think there is other owners that cap red line off w/o any issues with codes arising.
Old May 11, 2008 | 11:08 PM
dparsons06's Avatar
dparsons06
is that the line closest to the throttle body or the other one a little further up?
Old May 12, 2008 | 12:26 AM
srtratblock
It's the black line above the TB that has a 90 degree off IM going toward firewall. Tee into this line and you should be good to go.
