Tranny Problem, Please HELP :s
Old Jul 19, 2008 | 07:14 AM
STILL GH3TtO's Avatar
STILL GH3TtO
Default RE: Tranny Problem, Please HELP :s
I'll bet it was the gear selector, not your tranny or gear box. the symptoms you describe were verbatim to my issue.
Old Jul 19, 2008 | 09:41 PM
Kristjan SRT4's Avatar
Kristjan SRT4
The workshop checked in the enginebay and under the car and everything was connected there, does the gear selector have anything to do with that?
Old Jul 20, 2008 | 06:44 AM
AWH's Avatar
AWH
Yes. Check the pin on the gear selector. It's what the linkage cable and bushing attaches to. Hopefully that's the problem since it's not too serious, other than the fact that you cant really drive the car until you fix it.
Old Jul 20, 2008 | 12:49 PM
dparsons06's Avatar
dparsons06
The same thing happened to me, but i was going from 2nd to 3rd. When the dealership looked it over they told me that the fork got stuck and when i went to shift it all got jammed up and something blew up and put 2 holes in the side of the transmission, had to to get a new transmission. Luckily the warranty covered it
Old Jul 20, 2008 | 08:12 PM
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: Kristjan SRT4
This wasn't the shifting linkage or the cables. If this is the "fork" if you call it that, what can I do? Do I have to have another gearbox or can I fix this?
If it were a shift fork you could simply replace the shift fork and make sure there was no resulting damage done by any pieces floating around. However, it isn't likely to be a shift fork since they operate in gear pairs in this tranny, one for 1st and 2nd, another for 3rd and 4th and the last for 5th and reverse, 3 shift forks in all. If it were a shift fork it would be far more likely to lose 1st and 2nd or 3rd and 4th (which is one of the many things that happened to my '88 Shelby Z) and not the 3 yours has lost. If all the external components are operating fine then it must be internal, maybe just a broken shift cover component.
Old Jul 20, 2008 | 08:16 PM
Kristjan SRT4
I think I just have to get it to a workshop and get the gearbox out and make someone open it for me and check what is wrong :s 2 bad 4 me! This is just so much money over here, almost twise as much as you would pay in U.S.A
Old Jul 21, 2008 | 12:58 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
get it looked at. i guess from where you are any rebuild might be much much cheaper than a new tranny.
Old Jul 22, 2008 | 09:05 PM
Kristjan SRT4
I'm gonna go to my workshop tomorrow and I'm gonna check the gear selector and see if it's that. Now i'm just looking for the HOW TO FIX MY GEAR SELECTOR
I was told that I could find the HOW TO: Gear selector on the forum but I seem to be blind Can anyone give me a link if it's in here?
Old Jul 23, 2008 | 02:57 AM
AWH's Avatar
AWH
I could be wrong but I think the selector pin that breaks is on the shifter, not the tranny. If that's the case you may not be able to fix it without replacing the shifter. Maybe try putting your stock shifter back in and see if that works? Just an idea.
Old Jul 23, 2008 | 02:52 PM
Kristjan SRT4
http://www.srtforums.com/forums/f75/...lector-195243/
http://www.srtforums.com/forums/f75/...lector-336010/
Here are the shift selector how-to s, found them
