Is it OK to shift like this?
Old Jun 23, 2008 | 02:42 PM
srt4ever's Avatar
srt4ever
Default Is it OK to shift like this?
I usually press in the clutch to shift gears and/or go into nuetral, I noticed the other day that I could be in 5th gear and without pressing the clutch, grasp the shifter and put it into neutral!!! Is this a safe practice? Yes I know how to drive...Yes I can shift...No I do not go thru clutches like crazy! Just something I noticed and wondered if it was OK to do.
Thanks for the help
Old Jun 23, 2008 | 04:57 PM
Plan B's Avatar
Plan B
Default RE: Is it OK to shift like this?
I wouldn't....
Old Jun 24, 2008 | 12:10 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
yeah, you can just pull it out of gear. i do it myself at times (then scald myself for it). but its probably not good on it, as it would be a little stressful as it disengages under
Old Jun 24, 2008 | 07:35 AM
AWH's Avatar
AWH
Yeah mine does that too. It's easy to do in any gear if you let the engine decelerate in that gear for a second. As long as it's not struggling to stay in as you pull it out and it pops out easily I don't think its doing any serious damage.
Old Jun 24, 2008 | 09:04 AM
mopar222's Avatar
mopar222
it is fine as long as your gentle. I will sometimes shift mine without using the clutch at all, through all gears, with the excetion of first of cousre. Before there were syncros, this was the general practice.
Old Jun 24, 2008 | 09:52 AM
PSI Chick's Avatar
PSI Chick
yes but now that we have synchros it shouldn't be done. you're putting a lot of unnecessary strain and wear on your transmission doing clutchless shifting.
Old Jun 27, 2008 | 05:46 AM
AWH's Avatar
AWH
Yeah I sometimes clutchless shift myself, but it's usually for the shock value of passengers riding in my car. It's kinda funny when I tell them I will shift into all gears with no clutch and they can't believe I can do it. I got pretty good at it when my stock clutch was shot. I agree with PSI chick though, it does put unnecessary strain on the tranny and really shouldnt be done in cars with synchros.
Old Jun 27, 2008 | 12:10 PM
srt4ever's Avatar
srt4ever
HEHEHEHEHEHE
hOW NAUGHTY!
Old Jul 2, 2008 | 03:09 PM
SRT_Sizzle's Avatar
SRT_Sizzle
ORIGINAL: PSI Chick
+1 There's a good chance your weakening the ends of the cogs and could eventually end up chipping/breaking your gears in the long run. Do your tranny a favor and use the clutch.
