Mounting Gauge pods
Old Jul 10, 2008 | 10:48 PM
neon03se's Avatar
neon03se
Default Mounting Gauge pods
My stock boost pod and gauge are loose, how would I go about fixing this? I haven't really found anything on it. Thanks in advance!
Old Jul 11, 2008 | 02:49 AM
neon03se's Avatar
neon03se
Default RE: Mounting Gauge pods
bump
Old Jul 11, 2008 | 06:54 AM
AWH's Avatar
AWH
Haha I remember taking that thing apart awhile back to change the light bulb. It was a bit of a pain in the ***. I remember the "cup" having 2 screws at the top on the inside which attached to the underside of the dash. I will look again next time I get in my car and see if I can give you more info. The screws probably just became loose.
Old Jul 11, 2008 | 01:13 PM
2006DAKOTAV8's Avatar
2006DAKOTAV8
+1
Old Jul 11, 2008 | 08:31 PM
neon03se's Avatar
neon03se
so are there screws on the dash or the pod?
Old Jul 12, 2008 | 12:54 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
im reading it as both. there are screws that hold the dash in place and screws hold the pod in place.
Old Jul 12, 2008 | 01:54 AM
neon03se's Avatar
neon03se
any pics? lol
Old Jul 12, 2008 | 07:03 AM
AWH's Avatar
AWH
Yes, flamingpinhead is correct. There are screws in both the dash and the pod. I remember there being 2 screws for the pod, and I'm pretty sure I had to remove the center console cover and maybe part of the dash. I will take another look and give you a better idea of how I did it in the next day or 2. Weekends are really busy for me lol but I will get to it. BTW, you DEFINITELY should change the light bulb in the gauge while you have it open. I have an extra one of those bulbs too so I will give you the correct bulb # also.
Old Jul 12, 2008 | 02:25 PM
neon03se's Avatar
neon03se
^^cool man, i'll be patiently waiting the info, I do need to change the bulb actually, to me its a bit dim.
Old Jul 13, 2008 | 12:42 AM
flamingpinhead
Section Moderator
^i think its just such a pain to get to it you might as well replace it while your in there.
