fuel cut??
Old Jul 22, 2008 | 10:20 PM
  #21
kdestefano87's Avatar
kdestefano87
Default RE: fuel cut??
i also have a 2005 so its the same injectors as the stage 1.... im getting a popping noise out of my exhaust when it cuts on me... could it be spark plug blow out.
Old Jul 23, 2008 | 09:46 AM
  #22
PSI Chick's Avatar
PSI Chick
could be but spark blow out won't cause you to hit a certain rpm and stop. fuel cut however will.
just because you raised the boost doesn't necessarily mean that you'll hit fiel cut at the same time. it's dependant on a lot of factors, especially since you're on s0 and still have factory controlled boost. so temperature and humidity play a huge roll in when you'll hit fuel cut.
your best bet at this point is to lower boost to stock levels and get a wide band so you can see what's going on. you shouldn't be messing with boost without one anyway. change your plugs and wires just to be on the safe side for now, and get rid of that msd coil.
Old Jul 23, 2008 | 10:43 AM
  #23
kdestefano87
ok sounds good... whats wrong with the msd coil
