Random Question
Old Nov 26, 2008 | 09:23 PM
STILL GH3TtO's Avatar
STILL GH3TtO
Default Random Question
I want to run boost per gear and have a race fuel tune. Am I able to do this with my setup? I currently have d-tech fcbc and SCT
Old Nov 26, 2008 | 10:11 PM
HellaciousHemi's Avatar
HellaciousHemi
I would contact your turbocharger manufacturer. Is this rig only for racing? I ask because tuning it with racing fuel will be a waste of time if you drive this everyday. If its a weekend warrior rig sure but not an everyday driver.
Old Nov 27, 2008 | 09:28 AM
PSI Chick's Avatar
PSI Chick
yes you can. the dtec can hold four maps, so you can have one for race gas, and the fcbc can do boost by gear as well.
Old Nov 29, 2008 | 12:17 PM
HellaciousHemi
Hmmm, this would be you would have to have the entire system rid of non racing fuel then I am assuming. Since this is possible, what do you have to do to change the "maps" as you say that multiple can be held by the computer?
Old Nov 29, 2008 | 03:11 PM
PSI Chick's Avatar
PSI Chick
no you don't need to do anything other than what you would normally do when you go to the track. if you put in say 5 gallons of c16 with 2 gallons of 93 on a typical track day, that's what you want to tune at. tuning with pure race gas then using a mix at the track is going to cause you to run lean.
to change maps you have two options. one is to plug the dtec into your laptop and just change the map. if you're using a gameboy it's a little more of a pain. you have to basically copy the street tune to another map slot and then copy the map you want into the map 1 slot. it's not so bad if you only have two maps, any more than that and you're going to want to use a computer to do it.
many people keep three basic maps in their detc. one for the street, one for the track (typically higher boost and/or race gas), and a "bad weather" map that uses very low boost for the winter.
Old Nov 29, 2008 | 03:19 PM
STILL GH3TtO
I used to have the option where I had several maps and boost settings, but when I had my shop hook up the boost per gear they told me I could have one or the other but not both. I opted for boost per gear so I can get traction. On my d-tech now, I no longer have the multiple map options. is it hooked up wrong?
Old Nov 30, 2008 | 01:41 AM
PSI Chick's Avatar
PSI Chick
you should still have multiple map options. the maps are the fc part of the controller.
Old Nov 30, 2008 | 02:59 PM
HellaciousHemi
A lap top huh. Well I learned another thing today. Thats very interesting PSI, too bad I don't build Hi-po efi stuff yet. Gettin closer though.
Old Dec 7, 2008 | 10:17 PM
Ram48's Avatar
Ram48
Boost per gear uses one map for each gear so with the boost per gear used for 1st thru 4th. you use up all four maps .
Old Dec 9, 2008 | 08:03 PM
STILL GH3TtO
So there is no way to run boost per gear and race fuel??
