Reflash stage 1 on 04
Old Feb 25, 2005 | 11:33 PM
OrochiDio1's Avatar
OrochiDio1
Default Reflash stage 1 on 04
can it be done? its from a 03 im getting it really cheap if so
Old Feb 26, 2005 | 01:02 AM
BigMac's Avatar
BigMac
Default RE: Reflash stage 1 on 04
Yes it can.
Old Feb 26, 2005 | 11:07 AM
71RoadRunner's Avatar
71RoadRunner
I'm not certain, but I don't think you can get an '03 reflashed for an '04.
Old Feb 26, 2005 | 04:59 PM
glhs837's Avatar
glhs837
Sure can, the only ones that don't go back and forth are 05s. You can put an 03 into an 04 and vice versa.
Old Feb 26, 2005 | 09:32 PM
BigMac's Avatar
BigMac
Right. I've seen it done w/ no problems at all.
Old Feb 26, 2005 | 10:40 PM
OrochiDio1's Avatar
OrochiDio1
ok cool can any dealer do it? does it have to be in the car whats the deal?
Old Feb 26, 2005 | 11:05 PM
posthondaremoval's Avatar
posthondaremoval
It works for s1 or s2. I bought my stage 2 froma dealer i met at a track day last fall. It was bought for another srt-4, but the owner ditched. Rather than wait the 2 or 3 months to order one for my vin, I bought the kit, took it to a dealer who was srt-4 friendly, and they put it in, reflashed it to my vin, and put the s0 computer back in, so I could drive home and do the install of s2 w/toys in my friends garage.
No problems, just find an srt-4 friendly dealer, that is the key. 3 dealers told me it was impossible before i found the one who finally did it with no problem.
Good luck.
Old Feb 28, 2005 | 08:25 PM
RIPSIGUY's Avatar
RIPSIGUY
While were on the subject of flashes.....when I got my SRT4 I saw a flash for a "Mexican" turbo IV". I called tech line (i work at a dealer) and they told me not to do it. Traditionally, the Mexican cars had better programs (for performance). So I spend $300.00 on stage one. Now this gets interesting....when I plugged in the DRB 3 scan tool into the car, the stage one module description that comes up is "Mexican turbo IV" Hmmmmm. Any feedback on this????
Old Feb 28, 2005 | 09:50 PM
posthondaremoval
ORIGINAL: RIPSIGUY
Andale, andale, arriba! I got to see that speedy gonzalez car go, mang.
Seriously - that's interesting, I wonder if there is any performance difference. You should get it dyno'ed and find out if you have a better power curve...I would like to see, it might motivate me to find a mexican stage 3r add-on kit in the next couple of months.
Go Speedy! Andale, Arriba.[sm=gears.gif]
Old Mar 1, 2005 | 10:15 AM
glhs837's Avatar
glhs837
I'm betting the SRT gang used the Mexican program as a starting point and never renamed the filename. Similar to why the S2 with Toys PCMs set those pesky Auto trans codes, just easier to leave'em be.
Hit your stock PCM with that Mexican flash, see what happens Boost levels are up by 1-2 psi in S1, and the WOT shift feature should give it away. Or slap in Sexys car, since she's unmodded.
