Wheel offset
Old Feb 28, 2005 | 04:01 AM
PSI Chick's Avatar
PSI Chick
Default RE: Wheel offset
you'll probably need more than that. 1/2" or so. a 3mm is needed for a +42 that rubs.
Old Feb 28, 2005 | 04:03 AM
Barneydriver's Avatar
Barneydriver
ORIGINAL: OrochiDio1
ok i found out after surfing around that the stock offset on the srt-4 is 45mm so will the 48mm fit? thhttp://discounttiredirect.com/product/wheels/mbmwea.gm.xl.jpge rims look like that[IMG][/IMG]
i think stock is 40mm, isn´t it?
Old Feb 28, 2005 | 04:06 AM
OrochiDio1's Avatar
OrochiDio1
hmm well ill see.. like i said there for a STI but i got a good deal on them.. they look like motegi db6 i think there called..but i can make a spacer thats no big deal as long as they fit there 5x100 but i heard some people where having truoble with the subi type rims
Old Feb 28, 2005 | 08:29 PM
RIPSIGUY's Avatar
RIPSIGUY
I was told by someone here (Amy) that the design of the wheel spokes or hub area will be the factor requiring spacers. I believe this is true because I have seen two different wheels (designs) with the same offset, and only one required spacers.
Old Feb 28, 2005 | 09:14 PM
PSI Chick's Avatar
PSI Chick
yes, that is true. my last set of rims were a +42mm and needed a 3mm spacer. my current rims also have a +42mm offset and do not require spacers. spoke design plays a huge role in determining fit. but a +48 is beyond the questionable range of fitment.
Old Mar 1, 2005 | 06:17 AM
OrochiDio1's Avatar
OrochiDio1
alrite no big deal ill get like a 1/2 spacer.. just hope there enough lug to grab after.
Old Mar 1, 2005 | 07:26 PM
OrochiDio1's Avatar
OrochiDio1
i just got a email from tire rack and they said i can run a 48mm offset no problem! well see!
Old Mar 22, 2005 | 08:27 PM
RIPSIGUY's Avatar
RIPSIGUY
The caliper clearance is a pain in the rear. I orderd two different sets of wheels before I got a correct fit. Don't assume anything will fit until you put the wheel on and spin it. BTW, I have Excel Daytonas 18x7.5, 40mm offset going on as soon as my new tires get here. I'll post them when they're on.
Old Mar 23, 2005 | 02:24 AM
Tipop's Avatar
Tipop
I ordered a set of Axis reverb today with a 40mm offset, so we will see when they get here if I need spacers ^^
Old Mar 24, 2005 | 01:42 PM
04srt4lvr's Avatar
04srt4lvr
i was wondering can a wheel with a 40mm offset six 17x8 fit on a srt 4 if so what size tire would anyone recommend
