Wheel offset
Old Feb 28, 2005 | 12:40 AM
OrochiDio1's Avatar
OrochiDio1
Default Wheel offset
whats the highest wheel offset you can run on a srt? i bought some 48mm offset rims from a sti and im just hoping they fit.. there 17x7 5x100 with a 48mm offset
Old Feb 28, 2005 | 12:56 AM
dragon8master's Avatar
dragon8master
Default RE: Wheel offset
I checked all of the TireRack.com's 17x7 wheels for an '03 SRT4 and the different offsets they had were from +35 - +42. I would ask them before I took a chance on going through wheel bearings like changing oil.
Old Feb 28, 2005 | 01:09 AM
OrochiDio1's Avatar
OrochiDio1
well i check the wrx rims and the have offsets from like 34mm-50mm then i checked the srt and they had the same but i seen som 18's with like a 42mm offset.. so i dun know
Old Feb 28, 2005 | 01:14 AM
dragon8master
well, the 18's are irrelavent. The offset has to do with the overall width of the wheel and the distribution of weight on the bearings. Like I said...I would ask the EXPERTS at http://www.tirerack.com.
Old Feb 28, 2005 | 01:25 AM
OrochiDio1's Avatar
OrochiDio1
no i ment i found some 18inch rims with a offset of 42 mm for a srt i know the rim height has nother to do with the offset but like i said the wrx can take rims with the same off set as us.. but i did shoot tirerack a email
Old Feb 28, 2005 | 02:23 AM
OrochiDio1's Avatar
OrochiDio1
ok i found out after surfing around that the stock offset on the srt-4 is 45mm so will the 48mm fit? thhttp://discounttiredirect.com/product/wheels/mbmwea.gm.xl.jpge rims look like that[IMG][/IMG]
Old Feb 28, 2005 | 03:24 AM
PSI Chick's Avatar
PSI Chick
i doubt that a +48 is going to fit without spacers. +35-42mm seem to fit mostly, although some 42's require a small spacer to clear the caliper.
Old Feb 28, 2005 | 03:35 AM
OrochiDio1's Avatar
OrochiDio1
hmm to close to the caliper or not enough for the lug to grab?
Old Feb 28, 2005 | 03:43 AM
PSI Chick's Avatar
PSI Chick
too close to the caliper. some +42's sit on the caliper, which is why they need a spacer.
Old Feb 28, 2005 | 03:59 AM
OrochiDio1's Avatar
OrochiDio1
you know that was dumb of me ive been at work for 17 hours now.. my minds asleep so i should runn at least
4mm spacer?
