Spark Plugs
Old Mar 13, 2009 | 10:19 AM
srt4rez's Avatar
srt4rez
Default Spark Plugs
I know this has been said from time to time, but which iridium plugs are best for the SRT-4? Someone told me that the Denso is very good. What about the NGK or Autolite? Anyone has had an encounter with any others out there? Right now, I'm running Autolite Platinums which seems to be alright, but will definitely switch to iridiums, probably by next week.
Old Mar 13, 2009 | 12:16 PM
mldsrt4's Avatar
mldsrt4
ive been running denso iridiums in my car since i bought it, put about 20k on them so far, not issues, but i didnt notice any gains....id say if you run your car real rich they are most likley the plugs to go with. i went with them because of this forum and becasue i was recommended to use them by numerous people. As far as coil and wires i still have not heard anything persuasive on what set up to go with. Heard alot of people say MSD set up sucked but i have had them in for last 20k as well again with no problems, i went with MSD simply becasue its red.....best 'o luck
Old Mar 13, 2009 | 02:55 PM
PSI Chick's Avatar
PSI Chick
i used denso's, loved them. tried the ngk's, my car hated them. so did my boyfriend's. we both went back to denso's and never had a problem. smoother idle, good response. can't complain. and they last a lot longer than coppers.
Old Mar 13, 2009 | 04:51 PM
mxrnick's Avatar
mxrnick
yea the densos are the only way to go. i for sure noticed a smother idle over the stock plugs. i got them too because of this forum and to be honest ive never tried any other one but since these worked so well and still do why change em
Old Mar 14, 2009 | 12:52 PM
70x7's Avatar
70x7
ngks have always worked for me. Even for my high horsepower configuration. ngk 6309 when I had larger turbo, but on stocker I use and recommend ngk 4306
