Where do the sensors go?
Old Feb 8, 2004 | 01:27 PM
roachnigga's Avatar
roachnigga
Default Where do the sensors go?
I just purchased the SRT4. I ordered a TT, BOV, Injen Short ram intake, just as a beginning. My question is, once i install the Intake, where do the other sendors go? there's about 6 of them...
Thanks
PS. any other mods should i consider besides the bolts-on
Old Feb 8, 2004 | 10:44 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Where do the sensors go?
I don't know about the short ram intake...I heard they really didn't make as much of a difference as a longer, cold air intake. I'd also opt for an oil catch can, MSD spark plug wires and front strut tower bar. Those last three items can be had for around $175...less if you want to try the $20 catch can idea shown elsewhere on this forum...
Old Feb 9, 2004 | 10:24 AM
71RoadRunner's Avatar
71RoadRunner
Any good aftermarket parts will have provisions for all the sensors.
Old Feb 9, 2004 | 08:45 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
If you can't wait for the install directions, try checking out some of the photos of various ram intake installs on this forum as well as others...some of the photos are pretty good and show a lot of detail
Old Feb 10, 2004 | 02:16 PM
roachnigga's Avatar
roachnigga
Thanks Dust & 71 RR.
ill see what the intruction say when the hardware arrives. as far as the catch can Dust, i already purchased the order.
ill check around the forums to see how the installation is put. i also emailed Tech@turboneonstore.com for proper install
Old Feb 11, 2004 | 03:49 AM
71RoadRunner
Not a problem.[sm=smiley20.gif]
Old Feb 11, 2004 | 07:43 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Let us know it all works out...
Old Feb 19, 2004 | 04:21 AM
1qwk4's Avatar
1qwk4
most aftermarket intake will come with bracket for the sensors.if your facing the battery tray,the bolt on the left will be use to bolt down the bracket for the sensors. hope this helps and not confuse you even more.
Old Feb 19, 2004 | 06:09 AM
roachnigga's Avatar
roachnigga
Thanks, Dude
I just received the intake. the instruction has the T-bracket for the sensors. ill install them this weekend
Peace
