SHORT RAM INTAKE VS. REG. INTAKE
Old Mar 15, 2005 | 06:52 PM
amustlet's Avatar
amustlet
Default SHORT RAM INTAKE VS. REG. INTAKE
I HAD A QUESTION ABOUT INTAKES, IS IT BEST TO GET THE SHORT RAM INTAKE OR THE OTHER INTAKE. ALSO, WHICH BRAND WOULD BE BEST... THANX
Old Mar 16, 2005 | 04:04 AM
PSI Chick's Avatar
PSI Chick
Default RE: SHORT RAM INTAKE VS. REG. INTAKE
don't bother with a short ram, defeats the purpose of getting an intake.
Old Mar 16, 2005 | 05:35 AM
Black SRT's Avatar
Black SRT
If you're stock and don't care about bling, go with a drop in K&N. You really won't gain much from it.
Old Mar 16, 2005 | 09:47 AM
fivetoez's Avatar
fivetoez
i removed my airbox..........then clamped my K&N drop-in filter, to the STOCK tube that comes from the turbo,(aka: ghetto short ram)..............it made a difference.............. w/ stage 1 anyway................& it sounds MUCH better,.........Plus it did'nt cost me a dime. When i get some extra $$ im gonna buy the K&N intake......Oh , & btw, i run a 14.0 @ 102mph.....spinnin em in the first two gears...w/ a lousy 2.2 60ft. time...........soo i believe the cars runnin pretty good w/ said setup...............if i could only learn how to launch it better!________5TOEZ_________Funny thing is.......iv'e seen srt's run 12's on the STOCK airbox & filter.........soo take this post for what it's worth...
Old Mar 16, 2005 | 12:42 PM
turbeaux kid's Avatar
turbeaux kid
i got the AEM cold air intake and i love the way it looks and sounds. $250 well paid for
Old Mar 16, 2005 | 02:07 PM
posthondaremoval's Avatar
posthondaremoval
I have the AEM Short Ram and Love it - If you are worried about dragracing it's true, the cold air is going to have a cooler initial charge, but once running there is a ton of airflow in the cavity, and there is no heat issue. The throttle response is better and - I admit it - I like the sound. You get the same power gains, if not, better at speed, I would imagine, since the airflow is less restricted, and virtually the same temp as cold air at speed.
Old Mar 16, 2005 | 06:42 PM
black4's Avatar
black4
cai is much better than the stock air box.
Old Mar 17, 2005 | 08:57 AM
71RoadRunner's Avatar
71RoadRunner
I love my K & N Typhoon CAI, it looks great, performs great and sounds great.
Old Mar 17, 2005 | 10:59 AM
PSI Chick's Avatar
PSI Chick
ORIGINAL: posthondaremoval
actually that's not true. the vent in the hood is directional, so there is no air flow from there into the engine bay. the nose holes are used for the radiator to exchange air, and doesn't provide much air into the bay. when the car is up to operating temps, it's very hot in there, and a short ram is pulling in hot air from the engine and has no access to cold air at all. it's funny, even dcx mentions it in the infamous letter. our stock air box is a cai set up. the main reasons for upgrading to a aftermarket cai is two fold. one is that you can get a true 3" intake allowing more air into the system. secondly, it frees up a lot of room in the engine bay for other things, and to get access to parts down there.
Old Mar 17, 2005 | 11:32 AM
coyoteyz13's Avatar
coyoteyz13
what about where the infamous letter says that and aftermarket intake will cause the turbo to overspool. Isn't that what the wastegate is for?
