OCC help
Old Mar 19, 2005 | 01:33 AM
seanardy's Avatar
seanardy
Default OCC help
i already have an OCC in my car and when i opened the white filter i saw a thick residue so i just decided to cut out the tip of the white filter.do you think is better if i just take them out or just leave the tip cutted?im just curious because when i look at my OCC i saw the air at the top of my bowl flowing like waves around the bowl and i was thinking if im gonna take the white filter out it might suck into the outlet hose..what do you think?
Old Mar 19, 2005 | 01:38 AM
TX SRT MAN's Avatar
TX SRT MAN
Default RE: OCC help
if you have an aftermaket intake then i would suggest 2 OCCs, one on the pcv side and one on the intake side.
[IMG]local://upfiles/4313/A8B8BDA0B56348D9ACEC4CC34A83434C.jpg[/IMG]
Old Mar 19, 2005 | 07:02 AM
Black SRT's Avatar
Black SRT
Yes take the filter out. For some reason it will catch more oil. Please don't ask way because I have no idea why it just does.
Old Mar 24, 2005 | 03:25 PM
srt 4 russ's Avatar
srt 4 russ
Nice black SRT 4 I have a red SRT 4. Work for Northrop Grumman on the East Coast.
Old Mar 25, 2005 | 05:02 AM
Black SRT's Avatar
Black SRT
ORIGINAL: srt 4 russ
Cool, have they made you come to Whiteman?
Old Mar 25, 2005 | 07:55 AM
71RoadRunner's Avatar
71RoadRunner
I use to have the filters in mine, but I recently removed them since it seemed as though the oil might have been wicking through the filter and some getting past it.
Old Mar 25, 2005 | 03:47 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: 71RoadRunner
Good point, RR - I am surprised I haven't heard a comment about the wicking effect of the filter - it would explain perfectly the fact that it works better without it.
Old Mar 27, 2005 | 10:57 PM
71RoadRunner
I didn't know how it would do at first, the filter is hard like plastic, but the oil did soak through it because I checked the plastic opening inside the filter and it had oil residue suggesting to me that some has gotten through. This is why I have removed the filter. Judging by the OCC's design I'm thinking it might be better, less likely for oil to get through to the outlet, if I were to install it in reverse flow, since there is no filter the direction of flow doesn't matter and will flow the exact same amount of air in either direction.
