motor mounts?
Old Apr 3, 2005 | 03:09 AM
SRTFRANKE's Avatar
SRTFRANKE
Default motor mounts?
I've heard that motor mounts are a good first step to reduce wheelhop. Any suggestions for brand or type?
Old Apr 3, 2005 | 05:58 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: motor mounts?
It will help, in some cases it will get rid of all the wheel hop, but in most cases it will just reduce it. This goes for both solid mounts and motor mount inserts. I really like my Prothane race inserts, but they only reduced it in mine and for some they eliminate the wheel hop. Either way they will make a noticeable difference in the way your car launches, it will grab and go without the rubber band launch feeling. They will also transmit more vibration, not much though, and sound which will make your exhaust sound louder inside the car.
Old Apr 3, 2005 | 06:05 AM
Gump's Avatar
Gump
I also use the prothane race inserts... best 25 bucks you could spend for you car. you can feel the car better with them to add to what rr said.
Old Apr 3, 2005 | 07:11 AM
71RoadRunner
Same here, it was the best $25 spent. The only other mod this cheap is the OCC and it improves the engines lifespan and future performance. The other really cheap mods are the MSD wires and strut tower braces, followed by the Mopar STS and then the K & N Typhoon CAI.
Old Apr 3, 2005 | 07:15 AM
black4's Avatar
black4
i third that on the prothane inserts i say a great bang for your buck.
Old Apr 3, 2005 | 06:19 PM
coyoteyz13's Avatar
coyoteyz13
The prothanes are great.
Old Apr 4, 2005 | 02:59 AM
PSI Chick's Avatar
PSI Chick
psi-fi dogbones.
inserts are just not worth it if you plan on doing any semi-major upgrading. just the addition of s2 will make the inserts useless. i had inserts for about a year. they reduced wheel hop, but not all that much. plus i managed to completly destroy my lower mount with them in. they're ok for the normal driver that doesn't race at the track or really any pulls on the street, but if you plan on tracking the car, get a solid mount. the difference is quite noticable.
Old Apr 4, 2005 | 01:24 PM
posthondaremoval's Avatar
posthondaremoval
I agree completely on the s2 comment. I thought the prothanes were enough and they were definitely a good 25$ purchase, until s2 w/toys and some other stuff. Now - I think I'll be upgrading to actual mounts myself, shortly.
Old Apr 4, 2005 | 03:21 PM
whatneon's Avatar
whatneon
Anyone with oilpan cracking problems when changing the lower mount???
Old Apr 4, 2005 | 03:48 PM
Narcisse91's Avatar
Narcisse91
For what it's worth, I have prothane inserts and stage 2 and they work just as good as they did the day I installed them. That's not to say a complete replacement wouldn't be better, but the inserts are still enough to do the job in my case.
