Boost issues?
Old May 9, 2005 | 08:13 AM
  #21
roachnigga's Avatar
roachnigga
Default RE: Boost issues?
Ill recheck agin with leak soulution i aquired in my aviation unit. but i do know my ICP is fine, i checked that this weekend. You think 5mm will do it?
ill give it a shot
thnx
ORIGINAL: PSI Chick
leak test the car. you probably have a big old boost leak somewhere killing you.
try setting the wga to 5mm and reset the ecu after checking for leaks.
