View Poll Results: A poll
Denso
22.22%
22.22%
Torch
0
0%
NGK
55.56%
Autolite
0
0%
Other
0
0%
Voters: 9. You may not vote on this poll
Spark Plugs
Old Apr 21, 2005 | 07:37 PM
SRT_YA's Avatar
SRT_YA
Default Spark Plugs
Just curious to know what people preferred to use in their SRT's for spark plugs. If you could mention why you picked the spark plug you did, it would be helpful
Just for the record, the SRT-4 comes factory with Champions.
Old Apr 21, 2005 | 07:42 PM
PSI Chick's Avatar
PSI Chick
Default RE: Spark Plugs
i'm using the denso ITV22's. the champions died on me at about 2500 miles. i used the ngk's for about a year and were happy with them, except for the fact that i went through at least 4 or 5 sets in the span of that one year. i'm hoping the denso's will last me longer than the other two.
Old Apr 21, 2005 | 11:29 PM
Dartman69's Avatar
Dartman69
I've been using the NGK Iridium IX's, and I am very pleased with them. I've found that they've improved both the mileage and response of my SRT as well as burn alot cleaner than the stock Champion plugs. I chose to go with them since Mopar recommends an NGK plug set for use with the stage 3 turbo upgrade (still waiting for the stage three though lol).
Old Apr 22, 2005 | 11:36 AM
SRT_YA's Avatar
SRT_YA
Dartman,
When you jump to the stage 3 kit, also switch your plug's heat range to a 6 vs. the 5's that are recommended for stock use. (Assuming you are still using NGK's).
Old Apr 22, 2005 | 03:15 PM
posthondaremoval's Avatar
posthondaremoval
I am using ngk v-power's now. They were an improvement over the stock champions for sure. After about 8000 miles, they are pretty beat. I am about to switch to the denso's as I hear they work as well as the ngk's and last a lot longer.
Old Apr 23, 2005 | 08:36 AM
71RoadRunner's Avatar
71RoadRunner
I have always and will always use Champions, I've never had any problems with them. I have tried almost every brand made and noticed very little difference between any of them, so I'll stick with what I know and trust.
Old Apr 23, 2005 | 11:52 AM
roachnigga's Avatar
roachnigga
NGK Iridium gapped at .40. I have no complaints so far
Old Apr 24, 2005 | 08:12 AM
black4's Avatar
black4
densos for me.
