New Upgrade
Old Apr 27, 2005 | 05:45 PM
Silverrt4's Avatar
Silverrt4
Default New Upgrade
I have just recently installed the Mopar exhaust, an ICEMAN CAI, MSD wires, And NGK plugs. What do you think the next upgrade should be, for a pretty reasonable price, say around $50 - $200?
Old Apr 27, 2005 | 05:56 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: New Upgrade
for like 350 you can get a 60 mm throttle body and adapter plate. big thums up on that one.
for 120 shipped you can get the budget swaybar setup that a lot of people are selling.(great deal)26mm front and 19mm rear
What are you looking for, poewr or handling?
Old Apr 27, 2005 | 06:01 PM
Silverrt4's Avatar
Silverrt4
Handling might be what I should start upgrading b/c the power is there, but between handling and power, it doesn't really matter.
Old Apr 27, 2005 | 06:34 PM
SRT4STYLIN's Avatar
SRT4STYLIN
You might wanna check out getting the mopar short shifter, its like 150 with the booger bushings, posthondaremoval should know, hes the one that recommended it to me...
Old Apr 27, 2005 | 07:02 PM
srtfosho's Avatar
srtfosho
short throw shifter is what i wud go with looking at ur current setup/budget
Old Apr 27, 2005 | 08:56 PM
PSI Chick's Avatar
PSI Chick
stage 1
Old Apr 27, 2005 | 09:37 PM
71RoadRunner's Avatar
71RoadRunner
Between $50 and $200 you can get the Mopar STS, Prothane motor mount inserts, strut tower braces, OCC(s) and/or Mopar BOV. If you save up a little more then I would go with the Mopar Stage 1.
Old Apr 28, 2005 | 08:26 AM
posthondaremoval
http://www.performancespeedshop.com/...USPENSION.html
Good place to check out.
Check into budget sways from PT cruiser front (26mm) and ACR rear (19mm) for $110 with bushings. The car handles much better with these.
Old Apr 28, 2005 | 12:12 PM
Gump's Avatar
Gump
motor mounts and sts....
