weight reduction
Old May 2, 2005 | 04:15 AM
OrochiDio1's Avatar
OrochiDio1
Default weight reduction
im debating gutting the car.. how much weight has someone saved with back seat removeal/carpet/door panels eltc. if i can save over 50lbs from taking the stuff out from the driver seat back id consider it and put a cage in.. anyone acutlly weigh the seats/panels ect?
Old May 2, 2005 | 06:43 AM
roachnigga's Avatar
roachnigga
Default RE: weight reduction
It'll be over 50lbs for sure. But, im not goin that route... good luck
Old May 2, 2005 | 07:48 AM
71RoadRunner's Avatar
71RoadRunner
You could easily drop 50 lbs. by removing some items like you mention.
Old May 2, 2005 | 12:51 PM
posthondaremoval's Avatar
posthondaremoval
Add to that removal of the tar under the carpet and you'll drop another 20 lbs - but remember the cost is loss of sound deadening. With all that you can remove back there, I bet you'll surpass 100 pounds, no problem.
Here is some useful info. on lightening., I have used some of it and found it to be pretty accurate:
General Info:
Stock Curb Weight: 2970# (per Dodge)
Distribution: 62% front 38% rear
Fuel Tank: 12.5 gallons
The lightest documented SRT4 to date is the PVO SRT-4 Extreme Lightweight at 2400 lbs. It was stripped, with a single race seat, roll cage, and carbon fiber hood, front and rear fascias, decklid, and doors with Lexan windows, a side exhaust, SSR Comp wheels, Mopar Coilovers, and Stoptech brakes.
Removable Items:
AC system.........................22.5*
Front Passenger Seat.......43*
Front Seatbelts...................5*
Rear Passenger Seat.........10*
Rear Pass Seat Back..........30*
Rear Seatbelts....................7*
Rear Deck Cover................10*
Carpet...............................22.5*
Trunk Carpet and Pads......12.5*
Sound Deadening/Insul.....20*
Floor mats...........................6*
Spare Tire and Hardware...28*
Jack.....................................4.5*
CD Play................................4*
Wing....................................5
Passenger Air Bag................7*
Driver Air Bag........................?*
Head Liner............................2*
Moonroof............................26*
Side Windows.......................?
Heater Core/Blower..............?*
Variety-small trim stuff..........?*
Front Bumper......................20
Total Listed savings................259 lbs
Total w/moonroof removal.......285 lbs
*= NASA SRT class legal..........260 lbs
Replaceable Items:
Item_____________Orig. Weight___New Wt.___Change__Total Redux
Wheels and Tires*..................44................32...... .....12............48
Drivers Seat*..........................43................. 23...........20.............20
Hood ($900 race version).......30..................3...........27. ............27
Deck Lid ($800 race version)...23.................3............20..... ........20
Battery*..................................30...... ..........11...........19.............19
Springs/Struts (to C.O.’s)*......20................14.............6 .. ...........24
Brakes-front (TCE/Wilwood)*..11..................7..............4... ...........8
Brakes-rear (TCE/Wilwood)*......................................... ...........?18
Flywheel*.................................?....... ...........?............2..............2
Exhaust*.................................45....... .........18............27.............27
Underdrive Pulley.....................?...................?.. ...........?...............3 Radiator*..................................7...... ...........9.5.........-2.5........Damn!
Front and Rear Windows..........?...................?............ ?..............a lot
Rear Side Windows (to Lexan)*?..................?.............?......... ......?
Doors........................................?.... ...............9.............?...............?
Fenders.....................................5.5... .............?.............?...............?
Total............................................. ........................................213+ lbs
* Total (NASA SRT race class legal).......................................147+ lbs
Total Lbs. Saved - Street Trim 215.83
Total Lbs. Saved - Race Trim (Rear & Passenger Seat Removed) 287.58
Here is another compilation.:
SRT Part Lbs. Replacement Part Lbs. Lbs. Saved
Trunk w/ Spoiler 27.65 Trunk w/o Spoiler 22.90 4.75
Viper Style Seat 43.00ea ACR No AirBag Seat 34.65ea 16.70 (2)
Stock Battery 29.84 Hawker G13EP Battery 10.95 18.89
Stock CD Player 3.98 Sony ES Minidisc Player 3.44 0.54
SRT Rearview mirror 0.82 ACR Rearview mirror 0.63 0.19
AC System (All Underhood) 22.53 None 0.00 22.53
Stock Carpet 22.35 Carpet without Padding 15.10 7.25
Floormats 6.10 None 0.00 6.10
Sparetire and hardware 28.70 None 0.00 28.70
Jack 4.80 None 0.00 4.80
Trunk Carpet and Pads 12.75 None 0.00 12.75
SRT Rear Seat Bottom 10.10 ACR Rear Seat Bottom 9.15 0.95
SRT Rear Seat Back 29.95 ACR Rear Seat Back 27.95 2.00
Rear Middle Seatbelt 2.25 None 0.00 2.25
Foglights & Black Surrounds 0.93 None 0.00 0.93
Top Vibration Damper 0.24 None 0.00 0.24
Bottom Vibration Damper 0.36 None 0.00 0.36
SRT Dual Radiator Fan 7.85 ACR Single Radiator Fan 5.46 2.39
Front Mesh Grill 0.68 None 0.00 0.68
SRT Doorskin & Power Windows 8.90ea ACR Doorskin & Manual Windows 7.25ea 3.30 (2)
SRT Stock Rims and Tires 44.43ea Kosei K1 15x7 & Toyo T1-S 225/50/15 34.30ea 40.52 (4)
Stock Airbox & Intake Tube 6.01 Iceman Intake 3.41 2.60
Stock Battery Tray 2.60 OmniLite Iceman Tray 2.00 0.60
Front SRT Swaybar 10.73 Front Hotchkis Swaybar 7.94 2.79
Rear SRT Swaybar 8.02 Rear Hotchkis Swaybar 9.40 -1.38
Sound Deadening Material 20.08 None 0.00 20.08
Firewall Mat (Bottom Half) 5.63 None 0.00 5.63
Rear Deck 3.96 Rear Deck Carpet Only 0.34 3.62
Top Dash Panel 8.44 Panel w/o Padding & Insert 7.24 1.20
Right Rear Trunk Spring 0.40 None (Tightened Left Spring) 0.00 0.40
SRT Rear Exhaust Section 13.05 Titanium Muffler, Pipe & Hardware 9.58 3.47
Old May 2, 2005 | 07:50 PM
RIPSIGUY's Avatar
RIPSIGUY
Geez PostHondadude....I was gonna say loose thirty pounds with the spare and the jack (I weighed it), but you kinda of covered all the bases.
Old May 2, 2005 | 08:28 PM
PSI Chick's Avatar
PSI Chick
i removed the rear seat, spear tire and jack and weighed in at 2960 with me in it at the track last season.
Old May 3, 2005 | 12:18 AM
OrochiDio1's Avatar
OrochiDio1
looks like im going to gut it takes away function but oh well. my cage will probly add 30lbs to what i took out.
Old May 3, 2005 | 01:06 AM
seanie719's Avatar
seanie719
The only thing I remove is the spare tire. I put it in for long trips which is rare.
Old May 3, 2005 | 01:36 AM
LilSparkPlug's Avatar
LilSparkPlug
I have no spare tire or jack either. I'm not about to gut my car completely, and lose safety features (airbag) for 2 10ths of a second....
The only thing not on that list that would be removeable and is a "stock" part, would be the Kicker sub/amp/box combo and applicable brackets.
Old May 3, 2005 | 01:46 AM
whoosh's Avatar
whoosh
i say gut all but A/c and airbag and put racing seat(s) but keep the steering wheel
