Regarding a BOV
Old May 13, 2005 | 01:48 PM
PSI Chick's Avatar
PSI Chick
Default RE: Regarding a BOV
do not get the type r, your car will not be able to open it. the type s is fine if you are planning on staying with the stock turbo. if you plan on upgrading the turbo go with the type rs.
a bov costs about $180-200, upp is dependant on what company you get and if you get only the cold side or a full kit.
Old May 13, 2005 | 02:00 PM
roachnigga's Avatar
roachnigga
can the stock turbo, for now, open up the type rs? Also, what do you think of the kit that agp has... the Raptor?
Old May 13, 2005 | 02:07 PM
PSI Chick's Avatar
PSI Chick
the raptor fits like junk. don't buy it, i hate that pipe and you will too after trying to install it!
the stock turbo can open the rs, i had it on with my s2 for a while before s3 went in and it worked just fine.
Old May 13, 2005 | 02:10 PM
roachnigga's Avatar
roachnigga
what upp do you recommend? Also, do i have to buy any vacuum line & back plate for the RS?
