Drawbacks with even higher octane?
Old May 13, 2005 | 08:05 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Drawbacks with even higher octane?
The biggest concern with running the higher octane all the time is the increased engine temperatures, especially in hot weather. Your cars operating temperature will be higher and it increases the chances in overheating. The more free flowing your exhaust is the less likely it will overheat. An EGT gauge would be ideal as well.
Old May 13, 2005 | 12:28 PM
black4's Avatar
black4
love 104 oct had over 1/4 tank left of 92 oct filled rest with 104 hom worked like a champ to bad it cost 6.50 a gallon you do the math.lol
Old May 13, 2005 | 12:40 PM
mopar2ya's Avatar
mopar2ya
Thats why I like the Accelerator. 13.00 per can is tolerable. In 10 gallons of 91 is 100 octane, so it doesnt break the bank....totally
Old May 13, 2005 | 12:45 PM
black4's Avatar
black4
tried some of that toroco in a bottle but it kept kickng on the knock sensor in hom.
Old May 13, 2005 | 12:51 PM
PSI Chick's Avatar
PSI Chick
i used torco with s2. it is not as effective with s3 for whatever reason (well, ok i know the reason. s3 requires a higher "true" octane than torco provides). it is a good option for those people that do not have access to real race gas, but it's a better choice to use true race gas rather than an additive when you can imo. especially with s3.
Old May 13, 2005 | 12:54 PM
black4's Avatar
black4
thnx for input psi.
Old May 13, 2005 | 02:11 PM
posthondaremoval's Avatar
posthondaremoval
Well - you were right - vp is just fine. With a gallon or 2 of 94 left in the tank we added 10 gallons of vp unleadded. No knock so far in any gear. I haven't done a hwy pull in 4th gear yet, so that remains to be seen, but I don't forsee a problem.
And I have to say - after using HOM for the first time with 3"dp, no cat, 60 mm t/b, and all the other little tweeks - wow! The difference was noticable before, now the difference is night and day. The car came alive. For the first time, DAB 2 is faster than DAB 3 because of the traction advantage. DAB 3 makes the car a spaz in first gear and second. I need some slicks or drag radials for the track for sure, now. I can't wait to see what kind of times I post when I do get a chance to run it officially.
Thanks for your guidance on the race fuel, everyone.
