TURBO IS LOUDER NOW?????
Old Jun 9, 2005 | 05:11 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: TURBO IS LOUDER NOW?????
Sounds Like the infamous "pipe at the bottom of the turbo is loose" syndrome. Make a leak tester and check it. Good to do a leak test, anyway, you might have other small leaks, as well, that don't show up as easily without a tester.
Old Jun 9, 2005 | 07:08 PM
TRAV's Avatar
TRAV
THANKS, DO YOU THINK I KNOCKED SOMETHING LOOSE WHILE WIGGLING THE EXHAUST FREE?
Old Jun 9, 2005 | 08:03 PM
SRT_YA's Avatar
SRT_YA
ORIGINAL: TRAV
I would like to think "no"... but... stranger things have happened...
Old Jun 10, 2005 | 02:02 PM
roachnigga's Avatar
roachnigga
Everyone here has a valid point, Trav. Lets us know wassup
Old Jun 10, 2005 | 03:32 PM
TRAV's Avatar
TRAV
OK, WENT HOME LAST NIGHT AND CHECKED OUT THE EXHAUST. THE FIRST CLAMP ON THE MOPAR EXHAUST HAS THE HOLE IN IT AND IT WASN'T QUITE LINED UP RIGHT, SO I ADJUSTED THAT. I DIDN'T GET A CHANCE THOUGH TO CHECK FOR BOOST LEAKS. SEE, THE CAR IS LOOSING BOOST IN SECOND GEAR AT ABOUT 5000 RPM'S WHICH IT NEVER DID BEFORE. IN 3RD, 4TH AND 5TH IT WON'T LOOSE BOOST. IT HOLDS AT 15 PSI. IN SECOND IT WILL SPIKE AT 15, DROP OFF TO 13-14 AND HOLD TILL ABOUT 5000 RPMS AND THEN DROP TO ABOUT 11. IT USED TO HOLD AT 13-14 THE WHOLE WAY TO REDLINE BEFORE I INSTALLED TO MOPAR EXHAUST.
Old Jun 10, 2005 | 03:33 PM
TRAV's Avatar
TRAV
IF I HAD A BOOST LEAK, WOULDN'T IT DIE OFF IN EVERY GEAR, NOT JUST 2ND????
Old Jun 10, 2005 | 04:18 PM
RIPSIGUY's Avatar
RIPSIGUY
Reset the ECU!!!!!!! Remember, it has no idea you have made a change. You should reset it everytime you add a mod.
Old Jun 10, 2005 | 04:48 PM
TRAV's Avatar
TRAV
ISN'T RESETTING THE ECU DONE BY JUST DISCONNECTING THE BATTERY? IF SO I ALREADY DID THAT.
TRAV's Avatar
TRAV
IF NOT, IS THERE ANOTHER WAY TO RESET ECU?
Old Jun 10, 2005 | 06:56 PM
RIPSIGUY's Avatar
RIPSIGUY
The battery works fine. Put a mechanical gauge on and check it against the dash gauge.
