2 1/2 inch DP
Old Jun 24, 2005 | 01:08 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: 2 1/2 inch DP
Actaully, black - the maxxfab is setup without needing to be welded. you hacksaw ([]I know) off the 2.25 inch bottleneck in the borla,making it a true 2.5" and clamp it to the downpipe with a real nice compression/band clamp that is included. Improves the flow 19% over having the 2.25' restriction in the middle.
I like the setup a lot.
Old Jun 24, 2005 | 01:25 PM
PSI Chick's Avatar
PSI Chick
it's meant to use the clamp, but i had mine welded. i was using the clamp and it was leaking.
